Help needed on starting problem - Electrical - Classic Z Car Club Skip to content
Hi,
I need some help with a starting issue on my 1973 Z, auto trans, mostly original car. Car has been operating great then one day nothing. Car won't crank, just a clicking noise under dash on passenger side. I have a new battery; I checked & cleaned all connections from starter to ignition.
I tried starting it in neutral thinking it might be the neutral safety switch but same thing.
I tried turning the key to the start position and wiggled it up and down to see if the lock was the issue but nothing.
I read on the forum that the automatics have a starter inhibitor circuit (K-18) mounted on the firewall. The person replaced it and it cured the similar problem I had. The K-18 was replaced by Nissan with a new part number (25230-89918).   When I went to look for it, I found that it had been replaced again with a new part number (B5230-89985). I found one and it didn’t help, same issue.
Can I test the starter by running a cable from pos battery post direct to the starter? If so, what is the best way?
Any other suggestions?
The 3 attached photos are:
  1. The switches on upper kick panel of passenger side. The lower blackbone is the one that is clicking. Not sure of the name or if that needs to be replaced,
2. the Interrupter circuit on firewall,
  1. The clicking switch enlarged in case someone can identify it?
Edited by GregP
I use a long screwdriver to jump the the 2 big wires on the solenoid. Touch them both but you want the car in neutral and the key in the ON position. It scares the crap out of me but I'm a big ole sissy.
Good luck and be careful, use and old screwdriver because it's going to leave an arc burnt spot on your screwdriver. I like to have a person filming this to hear my scream. Just kidding but it really is good to have a witness in case something goes wrong.
That's the old skool way. A friend of mine years ago gave me a push button switch with two long wires attached and alligator clips on each end. One clip gets attached to the battery POSITIVE and the other gets clipped to the spade on the starter solenoid (remove the wire from the solenoid first). With the transmission in neutral, a push of the button should engage the starter motor.
They call them "Remote Starter Switch" on Amazon...
This problem is a common one on Z cars and has prompted many owners (including me) to install a STARTER RELAY. The start signal comes from the Ignition Switch and gets diluted by the interlock system and years of wire/connector oxidation. It's easier on that circuit if it just "sets" a relay - which then delivers power straight from the battery to the starter solenoid. (I also removed the overly complicated interlock system on my 260Z - just sayin' - personal choice...)
I'd take a test light or meter and see if the wire to the small spade connection on the solenoid is getting power when you turn the key to Start. You might have a cylinder full of coolant. Who knows.
If you're getting power to the solenoid but it doesn't do its thing then you might have a bad starter/starter solenoid. Hit it with a hammer.
Thanks for the replies! I tested the wire to the small spade connection on the solenoid, and it is NOT getting power. Picked up a remote starter switch and when hooked up to small spade connection on the solenoid the starter turns over nicely. The black switch I mentioned, that is under the passenger side dash is no longer clicking but still doesn't work. Is there something else I am missing?
After spending a lot of time trying to trace wires and unable to accomplish anything (with my limited electrical knowledge) I'm thinking of giving up and installing a starter relay as mentioned by cgsheen1. I couldn't find anything on the forum; can anyone provide a procedure for this?
Edited by GregP
In a 1973 240Z the start signal (battery voltage) is delivered through a Black/Yellow from the Ignition Switch directly to the Starter Solenoid in the MANUAL transmission version.
In the AUTOMATIC transmission version it feeds through an INHIBITOR SWITCH (a control and/or relay box) which assures the automatic transmission gear selector is in the proper position for starting. The Inhibitor Switch system IS NOT DESCRIBED in the Factory Service Manual (at least that I could find).
A starter relay is fairly simple - it uses the "start signal" (battery voltage on the B/Y wire) for the relay coil POSITIVE and the coil NEGATIVE is simply grounded. The supply to the relay switch is directly from the battery and the switch output goes to the starter solenoid. SO, the ignition switch activates the relay, which delivers voltage straight from the battery to the starter solenoid.
The manual start circuit is so simple I'm wondering if you have an auto trans frame... But, could be your ignition switch, fried wiring or connector.
Thanks for the info CG!
I have an automatic. I also found nothing regarding the inhibitor switch in the FSM but read about it online. My first thought was I needed a new inhibitor switch. I purchased one with no difference. I then thought the relay switch under the passenger side dash may be the issue since it is making clicking noises when putting the key in the start position. I have cleaned and visually checked all the connections. Ignition connector looks great. Now I'm wondering about the actual ignition switch. I just checked with the ignition switch in the on position, the relay under dash gets power. When you turn the key to start position, power is lost at relay & the relay clicks. I assume the ignition in start position is now cutting the power to relay and which prevents it going to inhibitor switch. I am thinking of replacing ignition switch since it's not expensive. A side note the wipers are now coming on intermittently when I have the key in the on position even though I have them off at stalk and now they won't work from stalk with the key in the on position. By the way the coil is getting power. Thoughts?
You can add a relay as cgsheen suggests, which will take the current to the solenoid out of the switch, or you can bypass all of the inhibitors and other safety features. I would start by checking for voltage on the wire that comes from S on the ignition switch when you turn the key to Start. If there's none there then you need an ignition switch. If you have voltage then you can add a relay or by pass each safety on the path to the starter solenoid.
It would be best to also test under load, using a test light that draws some current, like a taillight bulb.
I have found that the staked pins (copper color) can get loose and lose contact with the terminal. I had a 78 switch that would grab the starter then let go as I turned the key. The pin was loose. I fixed it with a hammer and a chisel. The terminals are marked with molded in letters. Look closely if you remove yours.
Edited by Zed Head
splee
Posed the question on the interweb and got this "AI generated" answer but it lines up with the automatic transmission info in the 1976 280Z FSM:
"The inhibitor switch on a 1973 Datsun 240Z automatic transmission is located on the transmission itself. It is typically found on the right side of the transmission, where it controls the circuit for the reverse lights and the starter interlock system. The switch is responsible for ensuring the car can only be started when the transmission is in Park or Neutral, and it provides a closed circuit for reverse when the transmission is in reverse. For a 1973 model, the switch is specifically designed for automatic transmissions and is not present on factory manual transmissions."
(We've had A/T Z cars in the shop and swapped out auto transmissions for manual transmissions, but I honestly don't remember the wiring at all.)
The electrical schematic has it wired with 4 wires: B/Y, B/Y, RB, R. (B/Y for the start circuit and R & R/B for the reverse lights)
The other relay in question is called "Seat Belt Relay" on page BE-2 of the FSM. Refer to "Fig. BE-1" item 17 "SEAT BELT RELAY (A/T MODEL ONLY)". The FSM shows that with 6 wires (as does the schematic - but the schematic does not label it "seat belt relay"): B/Y, B/Y, B/Y, B, G, G. (B is shown on the schematic as the GND symbol). BE-2 of the FSM shows the seat belt relay mounted on the firewall. Others, in other forums, do describe it as the "K-18".
Those are the only ones I see related to the start circuit - I don't think the black box under the glove box should be involved. (Is it the ACC Relay?)
And there's a post on ZCAR.COM: https://www.zcar.com/threads/not-the-inhibitor-relay-topic-again-1973-240z.424554/
