My 260z has a Mallory Unilite distributor, promaster Coil (#29440), and a Mallory Ignition Active Power Filter. Starting this year, when I drive it a short distance the engine just dies. When I go through the Unilite diagnotics, it show the ignition module has failed the test where I measure the voltage between the negative side of the coil and a ground with both the ignition module LED blocked and open. I've tried replacing the ignition module but the problem persists. Mallory's tech suggested a better coil ground so it now has a dedicated ground wire going directly to the battery.
I can restart the car after it sits until the engine compartment cools down. The ignition module then reads good. It will run for just a couple of minutes but again shuts down.
I don't think the fuel tank is building up a vacuum because opening the cap doesn't result in a rush of air and doing so will not start the car up again.
I recently added a new radiator cooling fan to replace a fan that stalls and draws a high current and installed an under engine splash guard so I should be getting better air circulation. I got rid of the dead head fuel system a PO installed and the fuel now flows back to the tank to minimize vapor lock. The fuel pressure gauge shows adequate fuel pressure.
Should I try a new coil or power filter?
Maybe it needs a better module ground. And/or heat sink.
The module looks like the typical GM module that grounds through the mounting points, and sinks heat through the contact of the bottom with the mounting surface.
Edited by Zed Head
