I'm being very deliberate in the naming of this part as ICF is what it's called in my 1972 FSM. This is the center part of the dashboard and holds the map light, central air vent, heater controls and radio.
What I want to know is what type of screws are used to attach this to the dashboard. I know they are 4 mm threads and probably have a Phillips countersunk head, but are they chromed or are they black?
In all honesty, my car's ICF will look nothing like its OEM counterpart as I've added a Vintage Air GEN II Mini HVAC system and a Retrosound Motor 4 radio. As I didn't have the heart to hack up my OEM unit (thinking someone doing a proper restoration might some day want it) I bought a reproduction, all black ICF from Motorsport Auto and did my modifications on it, which was to cut out the heater control section and fabricate a new escutchceon (that's what the FSM calls them) from a piece of textured black ABS plastic for the Vintage Air Streamline 4-knob controls.
Here's a photo of the ICF all mocked up on my dashboard. I have yet to drill holes in the (also fabbed) radio escutcheon for attaching the lower part of the ICF. Hence the need to know something about the screws.
IP mock up.pdf
Edited by Seppi72
added detail
They are black M4 x.7 yes. Oval head is what I believe they are called, not flat, slightly curved face. Phillips or JIS equivalent driver. Fairly long, like 25mm?
Thanks for that info, zKars. It's been so long since I removed the ICF from my car for this restomod that the OEM screws are long vanished.
Belmetric and Bolt Depot are my go-to vendors if the local Ace Hardware, Lowe's or Home Despot fail me. As for color, I have a complete collection of black spray paint cans in various states of gloss 😁
I was able to get M4-.7 x 20 oval head screws locally but had to paint the heads with gloss black rattle can. Needed fasteners to hold the A/C control panel on the ICF but no one has oval head thread cutting screws the right size. Ended up getting #6 x 3/4" wood screws which were also painted gloss black. Used a #6 countersink drill bit to prepare the plastic panels I fabricated (pix will follow soon). Looks great when assembled on my workbench and now looking forward to getting everything attached to the car.
Big milestone today: the dashboard is now back in the car since it was removed in 2008 at the beginning of this project. Lots of 'field mods' but that's the stuff that builds pride of ownership.
Hard to believe that 17 years of "just plain life" have passed by. But, I'm on a roll now and I hope to be back on the road by spring.
Not hard as I recall. Except for the clock, the overlays would slide over or under the needles to .get into position. I think I had to pull the hands off the clock bu they went back on easily.
Because there is a reputable supplier offering them - Z Car Depot - you could email or call them for information. They've been very good getting back to me with my questions.
