Okay I have what my friend claims to be an 85 280z, he took the interior apart, but didn't disconnect the battery that was about a year ago and now the car won't start it's not a battery issue if I spray gas into the air intake it'll stay running but if I stop it dies. Here are some pics I was able to take today. I'm guessing the injectors aren't firing is there a relay? Something I might be overlooking? Any and I'll help is greatly appreciated.
That's a 1978 280Z. The fuel rail and other parts tell the story. Somebody has installed a fuel pump in the engine bay, and it is not connected a to a tank. of the type that don't like to pull fuel. That fuel pump should be moved back to the original area by the fuel tank (if it still works) so that it can self-prime with fuel.
Download the FSM if you want to go deeper.
https://www.classiczcars.com/files/category/13-280z/
Edited by Zed Head
And be sure it's a high pressure pump for EFI. The fuel line going into the fuel filter should be as hard a rock with pump on.
Also the hose coming out of the filter will be hard from pressure. The fuel pressure regulator is what brings it down a little, 32psi IIRC.
You can get the metal fuel filter for $10 to $20.
Good luck!
Edited by siteunseen
The OP implies that it ran when parked, but the pump and hoses indicate that somebody tried to get it running using a portable can on the fender or in the engine bay. Somebody either messed with it in the "year" (probably 3 or 4 in real years) it's been sitting, or the friend only had it running on a portable can.
That's a good point I hadn't thought of that, I just took him at his word... imma have to look into that
Good luck!
Ok I will check on that tomorrow and will update you guys, thanks for the help. I appreciate it a bunch.
