Posted July 4Jul 4 comment_677189 So I took my dash partially out of my 73 240z to replace my heater hoses. I’ve since replaced the hoses and put the dash back. Now my car won’t crank. When I turn the key, the fuel pump runs and the relay on the passenger side floor clicks as normal but no crank. Any ideas? Link to comment https://www.classiczcars.com/forums/topic/69452-car-won%E2%80%99t-crank/ Share on other sites More sharing options...
July 4Jul 4 comment_677191 2 hours ago, nahurry said:So I took my dash partially out of my 73 240z to replace my heater hoses. I’ve since replaced the hoses and put the dash back. Now my car won’t crank. When I turn the key, the fuel pump runs and the relay on the passenger side floor clicks as normal but no crank. Any ideas?Do you have power to anything when the key is in ACC or ON?Have you checked for voltage at the black/yellow wire for the starter solenoid when someone is holding the key in START?Start there and tell us what you find. Link to comment https://www.classiczcars.com/forums/topic/69452-car-won%E2%80%99t-crank/#findComment-677191 Share on other sites More sharing options...
July 5Jul 5 Author comment_677193 I’ll check tomorrow, thanks Link to comment https://www.classiczcars.com/forums/topic/69452-car-won%E2%80%99t-crank/#findComment-677193 Share on other sites More sharing options...
July 5Jul 5 Author comment_677217 .65 at the bottom lug and 12 volts on the top lug Edited July 5Jul 5 by nahurry Link to comment https://www.classiczcars.com/forums/topic/69452-car-won%E2%80%99t-crank/#findComment-677217 Share on other sites More sharing options...
July 5Jul 5 comment_677218 1 minute ago, nahurry said:.65 at the bottom lug and 12 volts on the top lugYou need to add more detail. When, and exactly where? There are three "lugs". Actually two lugs and a spade. SteveJ is asking about the spade (black and yellow wire). With the key at Start.The 12 is a good sign though. Link to comment https://www.classiczcars.com/forums/topic/69452-car-won%E2%80%99t-crank/#findComment-677218 Share on other sites More sharing options...
July 5Jul 5 comment_677221 As @Zed Head said, pull the spayed ign. Off the terminal and measure the voltage. Black to Gand and red on the spade turn the key to start. Link to comment https://www.classiczcars.com/forums/topic/69452-car-won%E2%80%99t-crank/#findComment-677221 Share on other sites More sharing options...
2 hours ago2 hr Author comment_677927 11.26 volts Link to comment https://www.classiczcars.com/forums/topic/69452-car-won%E2%80%99t-crank/#findComment-677927 Share on other sites More sharing options...
1 hour ago1 hr comment_677928 21 minutes ago, nahurry said:11.26 voltsMeaningless Link to comment https://www.classiczcars.com/forums/topic/69452-car-won%E2%80%99t-crank/#findComment-677928 Share on other sites More sharing options...
