Hi guys,
I am chasing a rear clunk noise which happens when going over the road cracks and potholes. Pushing the rear of the car with hands in an up/down motion doesn't reproduce it.
I replaced all the bushings in the rear 10 years ago. I probably put about 1000 miles on the car.
First, I thought the noise was due to my read speaker deck, I removed it. Another thought was the deck lid, there is small play in the deck struts due to the loose bushing/pin attaching the struts to the mounting location.
I jacked up the car, removed the strut assemblies and checked the rear strut insulators. They are solidly attached, no play. However, I saw a hairline crack on the LH side.
I checked all the rear sway bar bolts, nuts, plus the R200 hardware, rear half-shafts bolts/nuts, fuel tank/pump, mustache bar hardware. 10 years ago I installed an aftermarket RT mount, there is a 1/8 in gap between the R200 and the RT poly bushing when the car is rested on the jack stands.
What are your thoughts? I went through a lot of posts about the rear end clunking (hundreds of hits lol), and I think I checked all of them on my car with the exception of that hairline crack in the insulator.
I am planning to order a pair of strut insulators to begin with (240z ones with an adapter, unless someone has a pair of later 280z ones in a good condition?).
Thanks!
https://www.classiczcars.com/forums/topic/69424-rear-clunking-noise-76-280z/
I doubt that hairline crack is the source of your problem, That crack probably doesn't go very deep. Hopefully it's just a surface feature.
So, the first thing I would check are the nuts on the top of the strut insert (down in the recess in the top center of the strut insulators). If one of them has worked their way loose (or were never tight to begin with), you would get a noise like what you describe. And you can't just "check for play" with the strut assembly off the car. That spring will extend to take up any available play. There would only be play with a load on the strut that has partially compressed the strut insert.
So was this noise always there, or is it something that has developed over time?
Did you replace the factory diff mount? When you use a bumper with the RT mount it essentially just replaces the strap. It reduces upward movement but the diff can also move downward if the stock mount is worn.
Also, the bushings and bumpers on the ends of the mustache bar look worn. If you crawl under the car and grab the mustache bar end with your hand you'll be surprised at how easily it can be moved up and down.
New bushings might help, although sometimes they can bring some diff whine in to the cabin.
Z Car Depot Inc
No image preview
Mustache Bar Bushings Poly Differential 240Z 260Z 280Z
Mustache Bar Bushings Poly Rear Diff Mount S30 - 800-172 (). New Energy Suspension black polyurethane bushings for 1970-78 Datsun 240Z 260Z 280Z mustache bar.
Edited by Zed Head
  1. I will check the insulator nut on both sides, will compress the springs to do it. The noise has developed over the past year. There is no clunking when shifting gears, it is the annoying noise going over small/large cracks on the roads. The roads here in WI are not as good as in CA.
    The factory diff mount was replaced with a brand new (then, 10+ years ago) Nissan diff mount. I just checked it - the rubber is solid, there is no play.
  2. I am ordering the poly bushing kit for the mustache bar. The diff whine will probably get droned out by my MSD-2225 fuel pump :-) anyway. I insulated the FP with some nice rubber padding, and it is still loud.
Appreciate your guys' ideas!
It is summer here, time to enjoy our toys. Last winter I upgraded my stock Bosch L-Jetronic to the microsquirt ECU with the inj/spark control, need to start driving the car to properly tune it.
Hi Charles, I started a thread a while back on hybridz in their EMS/Megasquirt forum: https://forums.hybridz.org/topic/136053-76-280z-microsquirt-project/#comments
It has been a journey, so far no regrets dumping the AFM/Bosch ECU etc.
Yeah, I would start there. Remember that you need to compress the springs to the point where you could remove that center nut on the strut, just like when you are replacing strut inserts. With the springs that much compressed, you will be able to check everything in that top mount assembly. The nut tightness, the plastic spacer, the integrity of the rubber, etc.
Do you have a rear sway bar? Another location that can easily produce clunk noises on small road bumps is the sway bar end links. But that's easy stuff... I assume you checked all that already.
Yes, I checked the rear sway bar, I replaced its bushings there too when I overhauled the suspension. Thanks for the tips!
I ordered the mustache bar bushings. I will probably need to replace my clutch master/slaves - they are original. My 'freshly' (10 years ago) rebuilt 5-speed from a ZX is giving me fits while putting it into reverse. With no engine running, I can't force it into reverse. With the engine running, I can rev up and shift. I am suspecting my clutch is not fully engaging? I also noticed I am missing my upper-stop bumper for the clutch pedal. I can't find that rod with a rubber stop in my spare parts box anywhere. I think it looks like a hood bumper stop?
Hi guys,
I replaced the mustache bar bushings and re-torqued my rear strut insulator lock nuts. I didn't notice any play there when the springs were compressed. The good news is that the clunking noise is gone.
Replaced the master/slave clutch cylinders/hydraulic hose. The old ones showed some internal brake fluid leakage. No more grinding while shifting into reverse. The clutch fork moves 12.5 mm (half an inch). The pedal is at 8 in, 15 mm of free travel before the slave starts pushing the rod. I searched this forum and someone mentioned that the 15 mm is a good number for a fork throw. I am guessing if mine was too short to disengage the clutch disk, I would have heard/felt it.
Thanks to all who helped with the diagnostics!
Glad the clunk is gone. I assume it was the strut nuts. A small amount of play in there can be tough to discern with gas struts and spring pressure helping hold things still. But if it went away with some torque on the nuts, I'm guessing that's what the issue was.
The fact that it appeared gradually over time is still a little disconcerting. Are they nyloc style vibration resistant nuts on the tops of the struyts?
