Posted Yesterday at 07:15 PM1 day comment_676586 Where in the world can I buy or does anyone have a fix for a speedo cable leaking where it screws into the transmission on a 72 automatic transmission Thank you Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/ Share on other sites More sharing options...
Yesterday at 07:16 PM1 day Author comment_676587 I am sorry. I need the seal for that Speedo cable attaches to the Automatic transmission Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676587 Share on other sites More sharing options...
Yesterday at 09:19 PM1 day comment_676589 I bought the seal from Nissan, p/n 32709-14600 if that's the one you need. Mine is a manual but the speedo housing should be the same. There's some more info in this thread.Here's some for sale...https://www.google.com/search?q=32709-14600&rlz=1C1VDKB_enUS1121US1121&sourceid=chrome&ie=UTF-8 Edited yesterday at 09:21 PM1 day by siteunseen Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676589 Share on other sites More sharing options...
Yesterday at 09:44 PM1 day comment_676590 This has the same part number. #51 in the microfiche.Datsun Z Transmission Case & Fit...Datsun Z Transmission Case & Fitting (Automatic-3N71B) (F... Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676590 Share on other sites More sharing options...
Yesterday at 09:55 PM1 day Author comment_676591 The seal I need is like the seal on the right Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676591 Share on other sites More sharing options...
Yesterday at 10:08 PM1 day comment_676592 From the thread, "That little Top Hat in the pictures only comes with a new Speedo cable.However all is not lost. It is just a secondary seal. You can go to home depot and get a flat rubber washer that will do the same thing. They come in various sizes and have approx a 1/8" dia inner hole." @Chickenman Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676592 Share on other sites More sharing options...
23 hours ago23 hr Author comment_676593 Great. Thank you Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676593 Share on other sites More sharing options...
23 hours ago23 hr comment_676594 The speedometer cables are the same. If you don’t know or haven’t heard, Go to “CarPartsManual.com”. Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676594 Share on other sites More sharing options...
23 hours ago23 hr Author comment_676595 Thanks for that. I will. Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676595 Share on other sites More sharing options...
23 hours ago23 hr comment_676596 Chances are it’s leaking on the speedometer housing itself. It’s been a minute but if it’s like the manual transmission there’s an O’ring and a seal like @siteunseen mentioned. Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676596 Share on other sites More sharing options...
22 hours ago22 hr Author comment_676597 Here are a few pics that are puzzling. The connection of the speedometer cable looks dry. The cable has a drip on it and the floor show fluid. Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676597 Share on other sites More sharing options...
22 hours ago22 hr comment_676598 I really don't know about auto transmissions but seems like my auto Camaro I had to check hot and in gear with the E-brake on if I'm not mistaken. Have you recently put fluid in? Could just be slight over fill? Good luck with it no matter what. Link to comment https://www.classiczcars.com/forums/topic/69421-at-speedometer-cable-seal/#findComment-676598 Share on other sites More sharing options...
