6 minutes ago, Patcon said:
So wheel bearings were too tight??
They definitely were. Did that cause the brakes pads to tighten on the rotors? There was some brake dust everywhere. I ended up doing 3 things at once, flushing the brake fluid. Disassembled the calipers, and repack and set the wheel bearings correctly. The wheel bearings heating up may have caused air in the brake fluid to expand and tighten the brakes, I don't know. I just finished it off by adjusting the pedal to the floorboard distance, it was 7", now it's 8". Same with the clutch pedal, it was an inch off. Then set the master-vac push rod length to 3.5mm below the flange surface. I had backed everything off while 15 miles away trying to get home, not knowing what was going on. Things are looking good now.
