Posted Saturday at 07:31 PM1 day comment_676006 I removed my fuel pump today and cleaned up all the mounting hardware in order to replace it along with with some new fuel hose. I've done this a few times on other z cars over the past decades. However, I've never replaced the fuel damper. I have removed dampers on at least two cars in the past with no ill effect. Can a fuel damper go bad? I suspect a damper doesn't have moving parts and it's there to prevent pulsations in the fuel delivery. My damper looks bad on the outside but it's canister is in solid condition. I doubt I could find a new OEM one if I wanted one. What could go bad with an OEM damper? Link to comment https://www.classiczcars.com/forums/topic/69363-79-280zx-fuel-damper/ Share on other sites More sharing options...
Saturday at 07:47 PM1 day comment_676008 What’s the problem you’re having? Link to comment https://www.classiczcars.com/forums/topic/69363-79-280zx-fuel-damper/#findComment-676008 Share on other sites More sharing options...
Saturday at 09:05 PM1 day Author comment_676009 I'm replacing the pump because of low fuel pressure. Looked like nothing back there had been touched since new. So that was the only problem. I alway suffer with the "while I'm at it" thing when I work on my cars. Link to comment https://www.classiczcars.com/forums/topic/69363-79-280zx-fuel-damper/#findComment-676009 Share on other sites More sharing options...
Saturday at 10:14 PM1 day comment_676010 My Dad always preached to not put old parts you can afford to replace back on the car.Lots of exceptions to that statement but you all know what I'm saying. Link to comment https://www.classiczcars.com/forums/topic/69363-79-280zx-fuel-damper/#findComment-676010 Share on other sites More sharing options...
