April 30Apr 30 comment_675948 Your diode wire would be the upright part of the "T". This a 78 drawing so wire colors are wrong, but the T L and S orientation is common across the alternators. Edited April 30Apr 30 by Zed Head Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=4#findComment-675948 Share on other sites More sharing options...
April 30Apr 30 Author comment_675952 1 hour ago, Zed Head said:The Dave Irwin adapter converts one of the 71 wires to an "L" wire. Here's a schematic from the 1978 FSM. 1978 was the first year of the internally regulated alternator.Interesting (to me), I just noticed that there is a resistor inline with the charge lamp. In the past I think I've seen discussions about what happens to charging if the lamp burns out. Apparently, nothing. Charging still happens.In your case, when the diode opened, there was no current through the stator coil. No magnetic field was produced so no charging happened.Love this discussion. I am learning a LOT. As a mechanical engineer, I do not look at wiring diagrams hardly ever. So this is a great review of circuits. Z cars have so much to teach! Edited April 30Apr 30 by Zedyone_kenobi Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=4#findComment-675952 Share on other sites More sharing options...
May 1May 1 comment_675965 21 hours ago, Zedyone_kenobi said:I then switched the Multimeter to Diode Tester. Red to black or black to red the Multimeter read OL.20 hours ago, SteveJ said:That would indicate a failed diode to me. Wouldn't you agree, @Captain Obvious ?Yes, that would indicate a failed to me as well. It failed open circuit.And by the way, for educational purposes... With the new digital meters, it's pretty much impossible to check diodes integrity using the resistance scale. It needs to be on the diode check setting. If you happen to have an old ANALOG meter with a needle sweep, you can often check diodes with the resistance scale. But analog meters, like the dinosaur, are either extinct, or headed that way.So what SHOULD you have seen? Using the diode check setting, you should have seen "OL" in one direction, and some small voltage in the other direction. Something like 0.50 to 0.80 Volts. Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=4#findComment-675965 Share on other sites More sharing options...
May 1May 1 comment_675966 18 hours ago, Zed Head said:I just noticed that there is a resistor inline with the charge lamp. In the past I think I've seen discussions The pics are dead (Cause photobucket sucks!!), but yeah:https://www.classiczcars.com/forums/topic/51963-internally-regulated-alternator-trivia-bootstrap-current/ ? Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=4#findComment-675966 Share on other sites More sharing options...
May 1May 1 comment_675969 3 hours ago, Captain Obvious said:The pics are dead (Cause photobucket sucks!!), but yeah:https://www.classiczcars.com/forums/topic/51963-internally-regulated-alternator-trivia-bootstrap-current/ ?Glad it was nine years ago instead of nine months. My memory shelf life is not terrible but not fantastic either. Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=4#findComment-675969 Share on other sites More sharing options...
May 2May 2 comment_675977 8 hours ago, Zed Head said:Glad it was nine years ago instead of nine months. My memory shelf life is not terrible but not fantastic either.Haha! I know what you mean.But wow... Was that really NINE years ago? I've been sitting in this same spot for nine years??? Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=4#findComment-675977 Share on other sites More sharing options...
May 2May 2 Author comment_675987 time flies guys. My new alternator comes in Monday. I will try just adding the regulator cap to see if that fixes things before I swap out the alternator. I have high hopes Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=4#findComment-675987 Share on other sites More sharing options...
7 hours ago7 hr Author comment_676137 Update:My new alternator came in and when I tested the voltage regulator cap the leads that go to the diode read OL in one direction and when I switched the leads it read 0.597 V. That is what a diode should do. Low and behold the alternator is now outputting voltage. :) Problem solved. Now I have a spare alternator :) Edited 6 hours ago6 hr by Zedyone_kenobi Link to comment https://www.classiczcars.com/forums/topic/69352-charging-fun-with-zedyone/?&page=4#findComment-676137 Share on other sites More sharing options...
