June 8Jun 8 comment_676550 Nice work, Captain Obvious. Thanks for your persistence in moving this forward. A few questions and comments specific to the Combination Switch:I see the Horn Relay, but I don't see the Horn Switch (talking about the 'switch' that operates when the driver pushes on the horn pad)Letters appear in some of the rows in Column 2 of the 'grid' for the Combination Switch (the letters are: A, B, D, E, F, M and P). Can you refresh my memory as to what they stand for?As currently depicted, the Wipers show only 'OFF' and 'ON' modes, with the logic within the 'ON' mode apparently trying to do double-duty for both 'HI' and 'LO'. I think that the switch's operation might be more clear if 'ON' is replaced with discrete 'HI' and 'LO' modes. See attached schematic, per my original post in this thread back in July 2024.As I also pointed out back in 2024, it's worth keeping in mind that the colours of the wires coming off the Combo Switch don't always match the colours of the wires to which they connect on the Vehicle harness. See below (bold-face letters are Vehicle-side, regular-face letters are Switch-side)... Edited June 8Jun 8 by Namerow Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676550 Share on other sites More sharing options...
June 9Jun 9 Author comment_676560 Namerow, thanks for the input, and also thanks for the work you had done previously with the wiring. Your previous work helped me with the diagram that I've been working on. So for the comments above...First, the horn. I understand the desire to have an actual switch depicted on the diagram. And in one of my earlier revisions, I actually did have one in there. But then I took it back out because I decided that I wanted to conform more closely to the original scheme depicted in the other areas of the combo switch. By that, I mean... There aren't any actual switches shown for any of the combo switch functions. Not for the headlights, the wipers... No switches for anything. Instead, "connection" is indicated by the existence of the dot. I though it would be closer to Datsun's original scheme to have a dot connection to ground when the horn is pushed.Next, the wipers. I haven't dug into that system at all, and I'm kinda hoping that I never have to. I turned mine on and the arms move, and that's hopefully all I need to know. So, with that said... Are you confident in the switch connections you have laid out? If you are sure, I'll change the diagram to what you indicate.As for the letters in the second column, I'm in the same boat as you... I think I knew at one point, but don't remember. I'll look into it.And lastly, you are correct about the change of wire colors on the combo switch side of the connectors. Problem is that situation exists all over the car. They got better with that in the diagrams for the later years, but for the early cars, the colors on the diagrams are the "colors of the harness". I'm sorry, but I'm in no position to add all the connectors for all the devices that plug into connectors and indicate the wire colors on both sides of those connectors. Haha!!! Thanks for the help! Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676560 Share on other sites More sharing options...
Tuesday at 01:27 PM3 days Author comment_676696 Defroster switch... When did they change from the black unlit design to the yellow backlit version?Here's a hoovered pic of the unlit black:And here's the yellow backlit version:The wiring diagram I've been working on shows the simpler black unlit version. When did they change to the yellow backlighted version? Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676696 Share on other sites More sharing options...
Tuesday at 01:29 PM3 days comment_676697 My 12/70 is black. And my 6/71 is orange/yellow. Still a wide range there. Edited Tuesday at 01:29 PM3 days by inline6 Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676697 Share on other sites More sharing options...
Tuesday at 02:30 PM3 days comment_676699 57 minutes ago, inline6 said:My 12/70 is black. And my 6/71 is orange/yellow. Still a wide range there.Interesting, my 12/70 car has the yellow switch. My S/N is HLS30-17486, I'm guessing your 12/70 car has an earlier S/N than mine. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676699 Share on other sites More sharing options...
Tuesday at 02:31 PM3 days comment_676700 My VIN is HLS3016530. I will double check my memory. It has been a long time since I put eyes on that switch. Edited Tuesday at 02:32 PM3 days by inline6 Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676700 Share on other sites More sharing options...
Wednesday at 04:59 AM3 days comment_676737 14 hours ago, w3wilkes said:Interesting, my 12/70 car has the yellow switch. My S/N is HLS30-17486, I'm guessing your 12/70 car has an earlier S/N than mine. My 12/70 #17770 has the black unlit switch. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676737 Share on other sites More sharing options...
Wednesday at 01:02 PM2 days Author comment_676746 Haha!! Unfortunately, it's not yet clear:inline6, when you get a chance, can you double check what you have on your 16530 car? Edited yesterday at 01:51 AM1 day by Captain Obvious Removed incorrect info. See below Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676746 Share on other sites More sharing options...
Yesterday at 01:41 AM1 day comment_676782 No-no, I said "My 12/70 (16530) is black. And my 6/71 is orange/yellow." Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676782 Share on other sites More sharing options...
Yesterday at 01:50 AM1 day Author comment_676783 My bad. Still a discontinuity, but I had it in the wrong spot:16530 has the black - inline617486 has the yellow - w3wilkes17770 has the black - Johnz1971 Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676783 Share on other sites More sharing options...
Yesterday at 02:58 AM1 day comment_676784 I've got to believe that w3wilkes' z switch was replaced/upgraded at some point in history.@w3wilkes How long have you owned your 12/70? Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676784 Share on other sites More sharing options...
19 hours ago19 hr comment_676797 11 hours ago, Johnz1971 said:I've got to believe that w3wilkes' z switch was replaced/upgraded at some point in history.@w3wilkes How long have you owned your 12/70?I am the 2nd owner of this car, I purchased it from the original owner in 1990. In talking to the original owner when I bought the car and a few times since I really doubt that the switch was upgraded/replaced and I know I didn't replace it.Since Datsun did a lot of work to increase production capability in 1970 it seems like that it is entirely possible that there were multiple production lines for the 240Z with lines being stocked with newer parts at different times as needed. Another difference on the interior of my car is my map light is hooded and some other 1970 built 240Z's I've seen the map light has no hood. Link to comment https://www.classiczcars.com/forums/topic/69026-1970-wiring-diagram/?&page=8#findComment-676797 Share on other sites More sharing options...
