Posted July 29, 20214 yr comment_625934 74 260 wiper motor just clicks when i turn on the wipers.. i assume the motor is seized.. the motor is out and does not spin.. any way to get it to loosen up and SPINNNN??? Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/ Share on other sites More sharing options...
July 29, 20214 yr comment_625935 Don't assume! Figure out how to direct wire it for testing Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-625935 Share on other sites More sharing options...
July 29, 20214 yr Author comment_625936 the end of motor that hooks to wiper rods does not even turn.. we compared to a good one that spins freely... Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-625936 Share on other sites More sharing options...
July 30, 20214 yr comment_625947 The car I bought had already replaced the OEM wiper motor with one from a Honda. Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-625947 Share on other sites More sharing options...
July 30, 20214 yr Author comment_625952 ya.. thats my next option.. i have the motor out and disassembled.. not sure if the plastic gear in there is stripped... all looks ok.. now i need to put it back together... how do i get the 3 spring loaded magnets back in there....???? can i take the gear side of the motor apart??? Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-625952 Share on other sites More sharing options...
July 30, 20213 yr Author comment_625958 how do i get this motor back together? Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-625958 Share on other sites More sharing options...
July 30, 20213 yr comment_625960 Bearings prob failed or something Fun thing in classics is you can take everything apart. Take the time to take it apart. It's an easy fix usually Edited July 30, 20213 yr by bartsscooterservice Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-625960 Share on other sites More sharing options...
July 30, 20213 yr Author comment_625975 I have it apart. Which bearing are you referring to? Motor seems to spin ok. I have not opened gear side yet. White gear looks a bit worn. But my issues was clicking when I tried to turn it on. So power was there. Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-625975 Share on other sites More sharing options...
July 31, 20213 yr comment_626064 I can't tell exactly, never taken one apart, but it looks heavily corroded. Check the motor and gear. Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-626064 Share on other sites More sharing options...
August 2, 20213 yr comment_626170 Does your motor have a relay on the side? Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-626170 Share on other sites More sharing options...
August 2, 20213 yr Author comment_626184 Yes. Motor has a relay on the side of it. Any way to fix it. Relay just clicks when it’s got power. Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-626184 Share on other sites More sharing options...
August 2, 20213 yr comment_626192 I had the same problem with the motor not running. I bypassed the relay and connected a battery straight to the motor, and it ran. Power goes through the relay before the motor, so I cleaned the contacts on the relay, and it worked fine. You might give that a try. Link to comment https://www.classiczcars.com/forums/topic/65657-how-can-i-unseize-a-wiper-motor/#findComment-626192 Share on other sites More sharing options...
