http://www.xenonzcar.com/s30/fsm.html
Page 17 in the `EF Engine Fuel` section of the factory service manual talks about how the oil-pressure sender interacts in the fuel pump system. Might be a problem with the  oil-pressure sender... I assume there is oil in the system?
So whats the current status of the car? what have you done? what is the current issue? The more specific the better 🙂
Edited by heyitsrama
I got a new fuel pump ,unclogged the injector, checked the AFM, replaced the broken watery temp sensor and now I’m checking the wiring harness and am going to clean all the connections
The car still doesn’t run but I’m having fun messing with it
6 hours ago, silentbug said:
And I’m confused about something
When you turn the key to the on position shouldn’t the fuel pump prime
No, the pump primes in the START position.
And I don’t know if this is normal but when I unplug the oil pressure sender the fuel pump starts
Incomplete information. That's like saying "My feet hurt when I stand up" without you mentioning that you're barefoot and surrounded by Legos.
Ok well couple questions just to clarify the is the start position the one that cranks or the on before the car cranks and what other details do you need about the oil pressure sender
This is normal for 1978.  It's a flaw in the design, but useful for testing the fuel pump circuit.  It should only happen when the key is On though.
Turn key On, remove sender plug, pump runs.  Only 1978 does this.
Edited by Zed Head
