6 minutes ago, Zed Head said:
This is just me, but if there are no pinholes I would run it as it is.  Make sure you have a good cap to keep the moisture out and maybe add a prefilter on the tank outlet.
Most people with Z's that don't have fueling problems probably don't realize how rusty the inside of their tank is.  No offense to those that don't know.  Go look and post a picture.
One of the keys to using Red-Kote is to make sure it's dried/cured before adding fuel.  Also notice that they do not say that all rust has to be gone.  Just most of it.
http://damonq.com/red-kote.html
http://damonq.com/TechSheets/Red-Kote.pdf
i think i’m just gonna run one last thing of acetone and let it dry good then do red kote and let sit for a week until i get done working on the mustache bar and u joint
I like to do easy experiments before big jobs, if I can.  You might take that rod you used, tie a rag or something to the end of it, put a blob of Red-Kote on it and plant it on the metal that you can see.  If it peels right off after it dries you might have a problem.  If it sticks hard you'll know you're good.  Or just drop a blob of Red-Kote down there and see if you can peel it off with that metal rod after it dries.
Just an idea.  I like the sealer concept for pinholes, not so sure on a pinhole-free but rusty surface.  Just me though.  Seems like you can take a tank that works and create one that doesn't, if things go wrong.  With pinholes you have a tank that doesn't work and you just end up with the same thing.
i think u might be right, and i’m pretty certain there’s no pin holes. i’m hesitant to do redcoat then make it worse . i can’t get that remaining previous sealant i believe is what it is to come off any better. i don’t know if the red kote will stick to the old stuff real good or not
If that stuff is old sealant then you're right to be careful.  Some sealers have a curing reaction that happens after the solvent is gone.  That will make it more difficult for new sealant to stick to it.
But, Red-Kote is apparently completely soluble.  So it can be stripped out if there's a problem.
dang good thing i didn’t do the red kote yet . i’m letting it dry out now. after that last acetone it does look just barely better. i think that sealant in there now isn’t gonna come out unless i take to a radiator shop but i’m gonna run with it way it is now. i blew through all the hose lines on the tank and could hear solid air throughout all of them.
installed the tank with new evap hoses and put a fuel filter right off the tank , swapped out the wires and still don’t start. i have no idea what to do anymore
Go back to something that worked before.
so i installed the original keyosan denki fuel pump i picked up. i primed the fuel system the way i did before by blowing back on the return line to fill up the fuel filter. started up and drove it around the block for couple minutes and let it idle for about 20 minutes. shut the car off let it sit for 3-4 hours went back outside and the fuel filter was still filled with fuel. started it up no problems starting. we will see if it stays that way while i’m gone for a few days
24 minutes ago, 7tooZ said:
Great work  rewarding isn’t it?
yes it is ! now i just gotta adjust the carbs. crappy thing is i won’t even be able to work on it since i’ll be away for a couple months.
