Posted May 14, 20187 yr comment_549290 Can someone please identify this. I have decided to remove dashboard and I found this relay underneath by the stereo. somehow PO cut the 2 black wires. Thanks Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/ Share on other sites More sharing options...
May 14, 20187 yr comment_549292 There should be a number on it. Look closely, it might be faded ink. Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549292 Share on other sites More sharing options...
May 14, 20187 yr comment_549294 I would be tempted to say it's the seat belt buzzer, but that should only have a black wire and a green wire. Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549294 Share on other sites More sharing options...
May 15, 20187 yr Author comment_549305 This where it was attached Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549305 Share on other sites More sharing options...
May 15, 20187 yr comment_549308 @krZing Your photos confirm that it is the seat belt warning as @SteveJ said in the above post. That is the same as is found in my 73 240z in the same location. Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549308 Share on other sites More sharing options...
May 15, 20187 yr Author comment_549311 Thanks for the reply Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549311 Share on other sites More sharing options...
May 15, 20187 yr Author comment_549313 Also not sure what this toggle switch for? I apologize for too many questions just trying to learn. Never work with electrical Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549313 Share on other sites More sharing options...
May 15, 20187 yr comment_549315 That toggle switch looks to be the kludge that the previous owner tried to do when the parking lights wouldn't come on. Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549315 Share on other sites More sharing options...
May 15, 20187 yr Author comment_549317 The wiring look original. I could be wrong Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549317 Share on other sites More sharing options...
May 15, 20187 yr comment_549318 That toggle switch is not a Nissan part. From the wire colors I can identify the circuits as parking lights (green/white) and dash lights (blue/red). Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549318 Share on other sites More sharing options...
May 15, 20187 yr Author comment_549323 Thanks Steve that’s why I ask the experts. I’m ready throw in the towel. very frustrating. Do you have any suggestions on after market harness and is it easier to go that route. Thanks Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549323 Share on other sites More sharing options...
May 15, 20187 yr comment_549327 For me, I just would repair the dash harness, but I am hard-headed that way. Link to comment https://www.classiczcars.com/forums/topic/60031-identify-relay/#findComment-549327 Share on other sites More sharing options...
