not the actual gasket, but a actual size scan of the gasket (and a ruler next to it) that goes between a cannon intake and a weber dcoe 40. i need to make something, but dont want to order a complete gasket kit if i dont have to.
thanks all
Edited by sweatybetty
https://www.classiczcars.com/forums/topic/58393-weber-carb-gasket-needed/
i really dont want to pull a carb off the car yet. im going to make some phenolic spacers and i need a pattern
I've got a Weber 40 and Cannon set up on a shelf in my junk room.  I'll get them down soon and see if that gasket is there, if so I can scan it for you.
Looking at this picture looks like I have them.  Give me an hour or so to get to it, just getting up this morning.
Are we talking about the same thing?  Those black spacers in between the carb and the intake?  Looks like 6 individuals to me.  Left and right?
2.5" long, 2.5" tall.  quarter inch thick with o-ring grooves on both sides.
I'll leave it off for a couple of days if you need something,  let me know. Cliff
Edited by siteunseen
a scan would be perfect :cool: im looking to print it out, cut along the lines and use it as a pattern.
i found the spacers on ebay, but the want $30+ for 2. if i have a pattern, i can make all 6 for about $25
You're gonna have to 'esplain what I need to do as far as scanning what you need. Can you go to "windows paint" or similar, take the first scans I sent and get everything to scale then print that?
site, thanks for the help. not trying to be a pita :D
can you scan it with a ruler or something like a quarter next to the gasket? that would give me a size reference to work with.
here is a scan of 2 dimes that i scanned and saved as a jpeg, then attach as a photo. it should print out to actual size
