Posted June 23, 20178 yr comment_523737 Any one have a 69 - 71 transmission crossmember that you are willing to sell?? Link to comment https://www.classiczcars.com/forums/topic/57970-69-71-transmission-crossmember-needed/ Share on other sites More sharing options...
June 23, 20178 yr comment_523805 WOW man, that's a big ask. If someone has one they probably need it for a car they have. Contact Atlanta Z in Norcross Georgia. They may be able to help you. Do you mind if I ask what happened to the one the car came WITH? Just curious! Link to comment https://www.classiczcars.com/forums/topic/57970-69-71-transmission-crossmember-needed/#findComment-523805 Share on other sites More sharing options...
June 24, 20178 yr Author comment_523854 Looking for one to experiment on to make room to tuck the exhaust higher in that area. Don's iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57970-69-71-transmission-crossmember-needed/#findComment-523854 Share on other sites More sharing options...
June 24, 20178 yr comment_523857 I don't have one I can spare, but I can give you pictures and dimensions if that helps. If you are considering using it instead of the later style, the mounting method is so different it would be easier to make yourself a custom one that works with your exhaust. Then you can taylor it to be exactly what you need. Link to comment https://www.classiczcars.com/forums/topic/57970-69-71-transmission-crossmember-needed/#findComment-523857 Share on other sites More sharing options...
June 24, 20178 yr Author comment_523861 I don't have one I can spare, but I can give you pictures and dimensions if that helps. If you are considering using it instead of the later style, the mounting method is so different it would be easier to make yourself a custom one that works with your exhaust. Then you can taylor it to be exactly what you need. ZKars thanks. I actually have one but didn't want to remove it while I play around with my ideas about what might work. Don's iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/57970-69-71-transmission-crossmember-needed/#findComment-523861 Share on other sites More sharing options...
