Skip to content
Series-1 Hatch Vent Duct Clips & Restoration Info Needed
What is the inner thickness dimension?  Looked back at the thread's drawings and I don't see it listed.
Edited by kunzma
  • 3 years later...
can someone talk me through the right way to remove the hatch vent assembly without breaking off the grill pins? the passenger side plastic vent and tube was loose and came right out, so I was able to flex the clip enough to get the hatch vent out. The driver side vent assembly is not budging, I can't see any of the clip hardware or grill pins to get to them - the vent is possibly held in with some weatherstripping snot - don't want to break the grill on that side, but I haven't been able to wiggle it loose.
Edited by Rreford
  • 4 years later...
On 2/8/2017 at 8:50 PM, kats said:
Hi Jim, fantastic! I agree drain tube , use original soft rubber one , it is very good.
I too looked my spare parts , a metal crip which attaches two plastic parts is there, I confirmed, thank you.
My wife said "is it for vacuum cleaner ? "
I have to keep it inside my parts box !
Kats
Hi all! Currently restoring the rear hatch in all its glory, and dug through this thread.
Does anyone know if the outer gasket/foam seal on the interior hatch panel (the one with the rubber flaps for rain, etc) is the same soft 8mm foam as is used on the vent shown here?
Looking to replace the degraded foam, and trying to figure out the correct material.
Cheers!
IMG_6962.HEIC IMG_6965.HEIC IMG_6971.HEIC IMG_6976.HEIC
