Posted December 31, 20168 yr comment_509264 Looking for original 240z black interior vinyl - complete Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/ Share on other sites More sharing options...
January 10, 20178 yr Author comment_509957 Up Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-509957 Share on other sites More sharing options...
January 10, 20178 yr comment_509970 8 hours ago, spoofan said: Up http://www.thezstore.com/page/TZS/CTGY/classic08a02a Edited January 10, 20178 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-509970 Share on other sites More sharing options...
January 11, 20178 yr Author comment_509999 siteunseen: thanks, I know of this kit. I was looking for original in good shape, if anyone was selling. But I will probably end up with this kit. Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-509999 Share on other sites More sharing options...
April 24, 20178 yr Author comment_518974 Still looking for original 240z interior vinyl. Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-518974 Share on other sites More sharing options...
April 24, 20178 yr comment_518985 Unless you get really lucky, your going to find that the original vinyl isn't worth re-using. Reasons: The old vinyl will likely have age-hardened in the locations where the factory adhesive was applied. So much so that it may have chipped or split along the edges. The hardening makes it difficult to make a tidy job of re-gluing the pieces into another car. BTW, If have found nothing (including 'vinyl softener' products) that will permanently re-soften this vinyl. Conversely, one of the bigger vinyl pieces -- the one that covers the transmission tunnel -- actually sags with age and ends up showing big, nasty-looking wrinkles that are very obvious. It's really difficult to make those sags disappear when you re-install the piece in another car. The old factory-applied adhesive is going to need to be removed before you can effectively glue the old pieces into your car. This is a long and tedious job. I recommend you just buy the kit. You'll end up with a better result and no one will ever know the difference. Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-518985 Share on other sites More sharing options...
April 25, 20178 yr Author comment_519079 Namerow - thanks for suggestion. Are there any differences (regarding looks) between oem vinyl and z-store? http://www.thezstore.com/page/TZS/CTGY/classic08a02a Thank you. Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-519079 Share on other sites More sharing options...
April 26, 20178 yr comment_519176 I can't comment from direct experience. I'm sure that someone else here has installed the aftermarket vinyl pieces and has pictures they can show... Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-519176 Share on other sites More sharing options...
May 10, 20177 yr comment_520580 i believe i have some good used Vinyl.. i will need to see where i put it. when i was taking it off my parts car it was in good shape and very flexible. Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-520580 Share on other sites More sharing options...
June 9, 20177 yr Author comment_522709 2fourtyzee: thanks, let me know if you find something. Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-522709 Share on other sites More sharing options...
June 9, 20177 yr comment_522736 About the only consistent complaint about the repro vinyl I hear is the looseness of fit on the rear strut towers. Otherwise the fit and appearance of the diamond embossing is pretty darn close to stock. I think I may have a new set of the repro stuff I'd let go cheaper than MSA's price if you decide to go that route. Let me know at z240@shaw.ca Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-522736 Share on other sites More sharing options...
June 9, 20177 yr comment_522738 Related question, maybe its own topic: Will repro vinyl fit over insulation like Dynamat on the tranny tunnel? Seems like it could ... Link to comment https://www.classiczcars.com/forums/topic/56770-interior-vinyl/#findComment-522738 Share on other sites More sharing options...
