Skip to content
Horsepower Estimate
My early 1974 260Z was recently run on a chassis dyno to tune the Mikuni 40PHH carbs.  The tuning is not complete.  But, so far, 139 bHP and 143 ft lbs have been measured at the rear wheels.  Based on the following drive train description, what are realistic performance expectations?
Thanks
Drive Train Description
Production date:              April 1974
Air box:                                K&N Lamborghini 3-carb filter in Jim Wolf Racing aluminum housing with Mikuni air horns
Alternator:                          60 amp
Camshaft:                           Racer Brown SS-54-110 – 236 degree duration at 0.025” lift with 0 lash, 110 degree lobe centers, and 0.480” lift net, and valve spring/retainer package
Carburetion:                      Mikuni triple side draft, 40PHH with 32mm chokes
Cylinder head:                      Decked 0.020”
        Bronze valve guides
                                                280Z intake valves, 0.173” dia.
                                                280Z exhaust valves
                                                Valves and seats grinded
                                                Built by Floyd Link, Torrance, CA
 Exhaust:                               Custom fabricated with flanged connections
Header:                Euro Car Anti-Reversionary, 1 ½” dia. tubing, 3 into 2, 2 ¼” dia. collector outlet
System Dia.:       2 ¼”
Resonator:          Borla resonator
Muffler:               Borla turbo muffler
Fuel rail:                               Custom fabricated to duplicate functions of the original system using original brackets
Ignition:                               New stock coil
                                                New stock distributor
                                                Taylor 8mm Spiro-Pro
                                                NGK Iridium spark plugs
Oil pump:                            ZX-Turbo unit
Pistons:                               Datsun 0.040” over, flat top
Differential:                        R180 limited slip, 3.545 R&P set, Bob Sharp Racing spare
Transmission:                    New 1978 280Z 5-speed
Size of the air horns (length)?
Spark plug # (5-6-7) and gap
Head work (port & polish)?
CR?
Distributor?
Timing set at?
No MSD or similar box?
Picture of header (seems to be too small)
R180 LSD in a 3:54 diff? And coupled to an "A" tranny - big gap between 2nd & 3rd as opposed to a "B" ZX tranny and a higher ratio diff.
These are all the answers I have at hand.  I would appreciate any suggestions.
Thanks
Size of the air horns (length)?  Standard short horns, 25 mm
Spark plug # (5-6-7) and gap  NGK 6637 BPR6EIX / 0.036
Head work (port & polish)?  Yes
CR?  Don't know.
Distributor?  Stock
Timing set at?  Don't know.
No MSD or similar box?  None
Picture of header (seems to be too small)  Dimensions are as noted.  See attached photo.
R180 LSD in a 3:54 diff? And coupled to an "A" tranny - big gap between 2nd & 3rd as opposed to a "B" ZX tranny and a higher ratio diff.  Gearing is stock 280Z.
I like the air cleaner and the fuel lines look good. You have quite a few lines running around the front of the valve cover. what are they? Sorry for thread jack...
FWI I spent some time looking at 0-60 calculators but couldn't find one that gave good results; need to be able to input more detail but couldn't find one like that...
The lines are fuel supply, fuel return to gas tank, carbon canister vacuum and canister purge.  The lines can be tracked in this photo.
1 hour ago, gnosez said:
That is one very nice engine and engine bay!!!
Yes, looks great!
Built by Floyd Link -- from BRE? Based on that, it should run as good as it looks! But for quickie comparison, there's at least one other 260 dyno thread around here:
Thanks for the link.  Based on this dyno test, my tune seems pretty good.  Floyd Link rebuilt the head in 1983.  This project is finally coming to an end.
Edited by fixitman
I would think that with some carb tuning, advancing the timing, and a better dizzy you should see another 10-20 hp. I base that on our L24 street/track engine with triple 44mm and a similar build as yours. We got 210@crank running 110 octane at 34 degrees advance with a CR of 12:1. The L28 and 3.2L engines in full race mode make 294 and 345@crank respectively. Those run between 13.1 to 13.7:1 CRs. We use a 75 dizzy (vintage rules), an MSD box, 8.5 Magnacor wires and NGK non-Iridium plugs (race fine wire instead).
Where may I ask did you get your R180 LSD? I would suggest a 3:70 or 3:90 ratio diff to improve the driving experience.
Edited by gnosez
Rebello recommended the 280zx dizzy with the matchbox IC.  He said he liked that unit more than the aftermarket distributors.  I installed one on my Rebello 3.0 and it made a massive difference over my worn out 260z electronic distributor.
