May 3, 20169 yr Author comment_494197 i wonder if you still have time to cancel your order? might be worth a try Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-494197 Share on other sites More sharing options...
May 7, 20168 yr Author comment_494436 well its been a while since ive updated this, so here goes all new front end parts, including ball joints, struts, upper bearing, tie rod ends, springs, polyurethane bushings and compression rod parts. everything was sandblasted and painted with black epoxy new toyota calipers and aluminum splash shields. the originals were gone, so i made some up at work. the aluminum is a little too thick, so the hubs rub just a tiny bit but that should go away as the hub wears the aluminum. new compression rod parts and cover Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-494436 Share on other sites More sharing options...
May 13, 20168 yr Author comment_494914 so, i now have working brakes after the rear conversion and a couple of leak repairs everything is good! all new calipers, bearings and rotors. i have new cable and stops for the parking brake cable on the way, so i hope to have that done next week. then i can get the diff and short shafts back in. that should be the end of the suspension. next up: new wiring harness Edited May 16, 20168 yr by sweatybetty Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-494914 Share on other sites More sharing options...
May 16, 20168 yr Author comment_495152 new wiring harness finally arrived. i have a feeling im going to get flamed a bit, but while im out driving and you are sitting in the garage trying to figure out electrical problems................ i first found this place http://kwikwire.com/ when chasing electrical problems on my power wagon. $300 and a few days later, i had a new-like truck. anyhow, here are a few pics 14 circuits, plenty of wire and every wire is marked to where it goes Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495152 Share on other sites More sharing options...
May 16, 20168 yr Author Popular Post comment_495153 headlight relays Edited May 16, 20168 yr by sweatybetty Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495153 Share on other sites More sharing options...
May 16, 20168 yr Author comment_495155 i still have a few things to do, and a couple of things that i forgot, like the power antenna wiring, but everything looks like it should work better than new Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495155 Share on other sites More sharing options...
May 16, 20168 yr comment_495183 What did you wrap the wiring with? It seems like that would be a real pain with the wires already run. But it's gotta be the best way to get the lengths right. Very nice. Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495183 Share on other sites More sharing options...
May 16, 20168 yr comment_495206 Very clean, there is a lot to be said for fresh wire and connections. I guess the fuse panel itself is water proof yes? If you are not a stickler for originality then there is no downside, just keep the old harness so it stays with the car. I just had a look at their website, $300 is a good price, is that a master kill switch under the panel? Chris Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495206 Share on other sites More sharing options...
May 17, 20168 yr Author comment_495225 9 hours ago, the_tool_man said: What did you wrap the wiring with? It seems like that would be a real pain with the wires already run. But it's gotta be the best way to get the lengths right. Very nice. that is plain old electrical tape. easy enough to remove or replace if i need to Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495225 Share on other sites More sharing options...
May 17, 20168 yr Author comment_495226 4 hours ago, grannyknot said: Very clean, there is a lot to be said for fresh wire and connections. I guess the fuse panel itself is water proof yes? If you are not a stickler for originality then there is no downside, just keep the old harness so it stays with the car. I just had a look at their website, $300 is a good price, is that a master kill switch under the panel? Chris i dont think the fuse box is water proof, but im not too concerned with that where it is. as far as the old harness, some of it will be cut and spliced to integrate the new with the old which is turning into somewhat of a challenge it amazes me that these cars even ran with all the extra wires (why run 4 when 7 will work even better) and connectors. no wonder so many owners have problems. and, no, there is no kill switch Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495226 Share on other sites More sharing options...
May 17, 20168 yr comment_495227 5 hours ago, grannyknot said: I just had a look at their website, $300 is a good price, is that a master kill switch under the panel? The manufacturers web page seems to indicate the switch kill's the coil circuit. Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495227 Share on other sites More sharing options...
May 17, 20168 yr comment_495234 looks nice and clean - i like it. on my 78 the majority of problems were at connections - all the various plugs that allow the loom to be split up into sections for install. since you're replacing everything, did you just forego all these connections, or did you use new/refurbished plugs? Link to comment https://www.classiczcars.com/forums/topic/52787-sweatys-rebuild/?&page=7#findComment-495234 Share on other sites More sharing options...
