Hats off to you my friend!
Thanks Matt!
Looks pretty hardcore mark! Looking forward to see your progress
Soon.... Very soon...!
Speaking of progress... Where's your's at????
Edited by wheee!
Almost two months and a few thousand dollars later, I am seeing the light at the end of the garage tunnel.... A few more sheets to go up on the ceiling, a little more vent work and a coat of paint and the interior shell will be done! After that, I will set up a couple benches and a shelving system and install the overhead fluorescents and the car project can finally begin!!!! whew....
WorkBench is in. Power supply and paper masking roll set up.
Moved the car outside to clean up under it...
Still a lot to do and clean up!
Sent from my iPizzle ringy dingy device....
The controls you see are for the sprinkler system. Top one is the remote rain gauge. They were already in when I bought the place so I had to leave them where they are. There is also a thermostat for the furnace and then the power panel. Below that is the 240v welding circuit.
; ipsSettings['maxImageDimensions'] = { width: 1000, height: 750 }; const ipsJsFileMap = [];
