Skip to content
Early 260Z Interior Clips - Seat Belts
I think these clips are for the seatbelts in an early 260Z. But it's been too long for me to remember exacty where they go. Can anyone help?
Thanks,
Fixitman
Tough one. I "think" these go under one of the belt mounting points (large hole for SAE 7/16" fine seat belt bolts ) and the small hole provides a place to put the screw that holds the cover, maybe on top of the rear shock tower? Did early 260 have that yet, If not then it must a clip that holds the plastic body of the retractor housing behind the seat. Hope this points you in the right direction.
I have an early 260Z but I'm pretty sure I upgraded to 280Z belts. Anyway, I should have the original 260Z belts around somewhere and I'm sure I kept everything together. I'll search my garages tonight to see if I have that part.
Chuck
Chuck
I'm thinking it might be inside the upper reel.
I'm looking at the Datsun microfiche right now. It looks like that part goes on the reel that attaches in the floor/rocker area. Here's the picture.
Chuck
[ATTACH=CONFIG]53389[/ATTACH]
Chuck
You found it.
Thanks for your help.
Fixitman
