I have a 72 240 I've had since new. My son and I restored it about 15 years ago. I was driving it the other day and the oil pressure gauge went to almost "0". I've checked the gauge by grounding the lead and it worked fine. I've replaced the sender and no readings, or very slight reading. If I take the oil filler cap off and look in, oil is splashing around inside the engine. I changed the oil and filter about 6 weeks ago. The engine runs and sounds fine. Any suggestion on what to look for next?
Thanks Don
https://www.classiczcars.com/forums/topic/40889-oil-pressure-gone/
Screw an analog gauge into the block temporarily and get a REAL reading. You might want to blow some air into the port on the block just in case it got plugged by sludge. I would also do a filter change for the heck of it.
Edited by cygnusx1
Having replaced my oil pump once, I wouldn't recommend it. It's a pretty simple and robust design, and I can't imagine it wearing out or breaking. Besides that, it's a bit of a PITA job, at least for one person. I agree with others above. FAIW, the problem with my car (my '75 from long ago) wasn't the oil pump, but rather the oil sender.
I had just replaced the sender before I made this thread. I guess the brand new one could be bad. I'll try and find a gauge that I can hookup to the car and test the pressure. Thanks to all for input and ideas.
Don
Don
I have found aftermarket senders to be pretty poor. If you haven't already, get a Nissan part.
Marty
