May 20, 201114 yr comment_356316 I look forward to your experiment's findings! FYI: Here ia a hack job of an 18" X 2.5" ID on my 280z: Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356316 Share on other sites More sharing options...
May 23, 201114 yr Author comment_356557 OK, next part. Let's say that I need to weld a tip directly to the outlet of a muffler. Let's assume the muffler outlet is 2" ID (so a 2" OD pipe would slip inside for clamping) and extends from the muffler case by 3". But since the muffler space on a 240Z is - as we know - already at the very rear of the car, slipping a 2" pipe in and then using the tip I want for the 2" pipe is too long. The tip could not be tucked in where I need it, at best it would be the 3" from the muffler case. _________________ | | ___| |___————————/ ___| |___ / | | ——————/ |_______________|So what I'm thinking is to use a tip with a 2 1/4" ID that will slide OVER the outlet, and could butt up flush to the muffler case. _________________ | | ___| |————————/ ___| | / | |——————/ |_______________|But ideally, I think I'd want some sort of a bushing that would make that a snug fit prior to welding. And this is my question - has anyone seen a bushing of this type? The ID would need to be whatever the OD of a 2" ID pipe is, 2 1/8" or so? and the OD of the bushing would need to be 2 1/4" so that a 2 1/4" tip would slide on.Any leads? I've tried googling but the results have been marginal. I may not be using good search terms. Edited May 23, 201114 yr by Arne Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356557 Share on other sites More sharing options...
May 23, 201114 yr comment_356568 If this car has a gnose front end then this muffler is the Fujitsubo Legalis-R. I have the same system, just not bolted on. Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356568 Share on other sites More sharing options...
May 24, 201114 yr comment_356637 Can you insert long thin wooden shims/spacers/popsicle sticks between the two, weld, then pull out the spacers? Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356637 Share on other sites More sharing options...
May 24, 201114 yr Author comment_356648 Can't remove them later, the tips I'm looking at are glass-packed. Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356648 Share on other sites More sharing options...
May 24, 201114 yr comment_356653 Good to know, Walter. Did you use a typical 4" diameter sausage?This is the muffler that I used, and it was just a little too fat.http://www.summitracing.com/parts/WLK-24215/ Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356653 Share on other sites More sharing options...
May 24, 201114 yr Author comment_356667 OK, if I do this I'll try one a touch smaller diameter.http://www.summitracing.com/parts/BIG-50252FLT/ Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356667 Share on other sites More sharing options...
May 24, 201114 yr comment_356695 Machine shop with a lathe can build you oneorYou can use a metal foil tape to wrap the inner pipe to build up a spacing... It should not rattle after it degrades from the heat of welding and exhaust. Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356695 Share on other sites More sharing options...
May 25, 201114 yr comment_356783 OK, next part. Let's say that I need to weld a tip directly to the outlet of a muffler. Let's assume the muffler outlet is 2" ID (so a 2" OD pipe would slip inside for clamping) and extends from the muffler case by 3". But since the muffler space on a 240Z is - as we know - already at the very rear of the car, slipping a 2" pipe in and then using the tip I want for the 2" pipe is too long. The tip could not be tucked in where I need it, at best it would be the 3" from the muffler case.So what I'm thinking is to use a tip with a 2 1/4" ID that will slide OVER the outlet, and could butt up flush to the muffler case. But ideally, I think I'd want some sort of a bushing that would make that a snug fit prior to welding. And this is my question - has anyone seen a bushing of this type? The ID would need to be whatever the OD of a 2" ID pipe is, 2 1/8" or so? and the OD of the bushing would need to be 2 1/4" so that a 2 1/4" tip would slide on. Any leads? I've tried googling but the results have been marginal. I may not be using good search terms. I did just that with my exhaust when I made my tip. I centered it visually and tacked it straight to the muffler. Honestly once it's welded you won't need to worry about a snug fit. Once there's a weld bead around the pipe, it won't be moving anywhere. Or another option, cut the outlet off the muffler and weld the new tip on. You could leave a 1/4 inch to help center the resonated tip. With the original outlet cut short enough, you'll never see it even if it's not totally perfect. If you really worried about a shim, you can get some appropriate diameter steel round stock. Cut 2 to 4 short lengths (or bend 1 longer length around the outlet) and use them to shim/center the new tip. oh, I'm going to guess the resonated tip is chrome, mask that thing with masking tape and wrap it in leather or some kind of weld splatter blocker. Weld splatter will stick to the chrome and ruin the finish Edited May 25, 201114 yr by 70 Cam Guy Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356783 Share on other sites More sharing options...
May 26, 201114 yr Author comment_356881 Well, I think I'm getting close now. I'm pretty certain that what I'm envisioning will work, so it's about time to put my money where my mouth is. I think I'll buy and fab the rear muffler/tips first, then once that's done, I'll get the MSA system and the final few bits. Got to find someone to do the welding for me as I don't have that equipment myself.Stay tuned, film at 11:00.... Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-356881 Share on other sites More sharing options...
June 18, 201114 yr Author comment_359056 Parts ordered. Crunch time coming up. Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-359056 Share on other sites More sharing options...
June 21, 201113 yr Author comment_359312 In the immortal words of Marvin the Martian, "Delays, delays..."http://www.youtube.com/watch?v=ppGtDOG7ujkWhile the parts for the rear muffler swap are scheduled to arrive tomorrow, I got an email from MSA saying the system itself is backordered, 2-3 weeks out. I can do some testing w/o the entire system, but don't want to weld anything up until I can test fit it.Dang! Edited June 22, 201113 yr by Arne Link to comment https://www.classiczcars.com/forums/topic/39611-customizing-my-msa-flanged-exhaust/?&page=2#findComment-359312 Share on other sites More sharing options...
