Rubber? I swear these are cork material. I'll see if I can improvise something. I can probably look at the housing and get an idea of what shape it needs to be but if anybody has a pic that would be helpful. Just the cushion. Everything else is good.
Also, does anyone know the length of the mechanical fuel pump bolts? I can get the thread pitch but I'm not sure how thick the spacer is so I can only guess at the length I need. I have several sizes of stainless socket head bolts so I'm hoping I've got something I can use.
Fairly busy weekend:
Go to store to pick up necessary supplies - Check
Cut and install padding for tranny tunnel - Check
Install vinyl on tranny tunnel - Check
Run antenna and speaker wire - Check
Install gas filler neck and fuel door knob - Check (Black Dragon fuel flap doesn't fit right on early series 1)
Install Firewall Insulator - Check
Install new pedal pads - Check
Install blower motor and heater core - Check
Install new heater inlet and outlet hoses - Check
Store original braided hoses for no apparent reason - Check
Clean and install throttle linkage - Check
Sand, Ospho and POR fuel tank - Check
Sand and paint vapor return tank - Check
Sand and paint radiator - Check
Install radiator - Check
Sand and paint fuel tank straps - Check
Install rear diff by myself - ROFL (Can this even be done solo without a lift and tranny jack?)
Clean and polish side markers and install - Check
Fill and bleed clutch and brakes - NO
Install bead blasted distributor - Check
Polish and install tail lights - Check
Install tail light surround - Check
Remove PO's blue overspray from zinc plated parts - Check
Install wiper tubing and nozzles - Check
Wrap wiring harnesses with new electrical tape - Partially completed
Install drive shaft - NO
Install Half Shafts - NO
Figure out where all these extra vacuum hoses and linkage parts go - :stupid:
Install vapor return tank - NO
Clean and install license plate light - Check
All in all a fairly productive weekend. If my wife didn't have me running errands until 2 pm Saturday I might have gotten it all done. :mad:
John
Edited by JohnnyO
Well, yesterday actually...
Got my next door neighbor's Green 1972 Automatic 240Z "on the road" for the first time in almost 3 years. She is the original owner and want's me to do a refresh on hers when I'm done with mine. Has some rust in the quarter panels under the doors, but not terminal. Will get it taken care of when it goes in for paint.
Sand' date=' Ospho and POR fuel tank - Check
John
Write up insanely long weekend checklist recap & post to CZCC - Check! ROFL
