This is Zedyone_kenobi's ride and mine will be a near clone of his. Same color, same wheels. The only difference is that I have the full front air dam on mine. Dupli-color has already supplied the paint for it!
Just one small piece left to fab up for the drivers rocker before getting onto sanding....
Pattern -
Worlds best metal sheer -
Over to the brake -
Putting a bend into it -
After welding it in and applying seam sealer to the edges, it was done. A quick coat of the Duplicolor undercoating and it blended right in.
Then I spent the next 4 hours sanding and stripping the engine compartment paint....yuk.
Edited by e-tek
Its coming along nicely, I spent all day sitting on a stool inside my engine bay sanding as well. So I know what you mean. It is starting to look like you are going to pass me.
Dan
Dan
Just catching up Dan!
Just read through the whole thread.. I'm in awe! Great work on the rust repairs! Can't wait to see more!
Well thank you Sir!
Found one last tiny bit o' rust that needed a patch, then got some filler on 'er - it's coming along now!
Can't wait to get to the FUN part!
Great retoration work your doing. This is one of the threads I like to follow because of the good detail and I admire your workmanship. It will be a great car when its finished.
Thanks very much - I'll be getting a LOT done on the body this week - so stay tuned!
Lots of repairs where done in the front wheel wells of the 240Z, so I put another coat of Dupli-color's Undercoating on some thin spots -
...and got very close to finishing the quarters -
A final sanding and they'll be ready for primer!
Got the windsheild out today as well -
