Skip to content
Chrome engine fan
Does anyone know, does anybody make a chrome fan to replace the original plastic engine fan in the 72-73 240's? Thanks, just thought it would be a cool dress up for under the hood.
I'm not aware of anyone. You might want to look at a 70-71 fan, they were metal. Then get it chromed. Problem is, I believe, the reason Datsun went to plastic was due to the rivets giving way on the metal ones and fan blades going through the hood.
That and the fact that the increased weight of the metal fan was very hard on water pump shaft bushings.
I've never tried it before, but you CAN chrome plate the plastic fan, if you apply something called "Silvaspray" first. Silvaspray is a conductive substrate that is sprayed onto plastic that makes the surface conductive, and therefore, electroplate-able.
Caswell sells the stuff, as well as plating kits for all metals: Chrome, copper, nickel, silver, gold, bronze, etc. Link is HERE:
http://www.caswellplating.com/kits/silvaspray.html
At one time an aftermarket fan called a "Flex Fan" could replace the stock fan. The blades were chromed, and were thin enough to reduce their pitch at high RPM by twisting.
