Skip to content
Datsun-240z Vs Fairlady-z432
Hi Kats,
I found 2 more photos of the boot after it was removed from the car.
Perhaps it's not OEM as you say and aftermarket? I always thought it was original but now I think you may be correct?
Gavin, yes I checked that one . Nice boot :)
I wish it used more bold thread,  with wider parallel stitchings along the joint .
Kats
Here is a development of the boot.
I think I can replicate 2 more from the vinyl sheet if I have the two grommets.
Kats
Each boot has each stitches. The NOS boot (shown on the left)  has decent stitches than my used boot.
And this is the point , if it has decent stitches, you will see the square around the grommet.
Kats
Edited by kats
I received the two grommets from Mike and I will be reproducing both. There is a slight .5mm difference in the heights of each.
nix240z, that is a great news, I am looking forward to seeing a reproduction grommet.
And thanks to Mike  provided sample grommets.
Kats
Edited by kats
The grommets turned out very nice.
Since there is a slight .5mm difference in the heights of each, I will offer both as a combo.
http://www.240zrubberparts.com/apps/webstore/products/show/7723543
Thank you so much nix240z, it turned out very nice and lightning quick ! Even more coming with a bonus extra.
I am just amazed  of your ability of making products. I will place an order with some of your products.
Kats
Edited by kats
Hi, seeing those conversations of  'reploduction' here and there, now something is coming up in my mind.
I am having fun to list parts which are NLA from Nissan and other venders today, not only that , I picked those parts up which are visible at a car show and are very likely missing or deteriorated through the years.
I do not want nix240z to feel that he is obligated to do it. Do not take it seriously, just I want to show what is in my mind.
1/battery cable clip
2/fuse cover
3/fuse cover stopper teeth
4/flasher knob
5/early spare tyre holder rubber cover
6/luggage belt clip
7/door dove tail original style
8/ 1971 and later shoulder belt clip
9/seat belts clip
10/early shoulder belt anchor washers
11/early tyre stopper rubber band
12/ early seat bottom side cover
Kats
Edited by kats
1/battery cable clip - I have never seen this but could do this one. I would think it is metal with a rubber coating. More pictures and a size drawing would help out.
2/fuse cover - the white lettering would be hard so leaning to no.
3/fuse cover stopper teeth - could do this one.
4/flasher knob - I cant figure how to get the knob off
5/early spare tyre holder rubber cover - working on this one right now.
6/luggage belt clip - could do this one
7/door dove tail original style - no
8/ 1971 and later shoulder belt clip - could do this one
9/seat belts clip -could do this one
10/early shoulder belt anchor washers  - could do this one
11/early tyre stopper rubber band - would pass on this one, new urethane rubber does not like to be stretched for a long period.
12/ early seat bottom side cover - working on the set right now.
I really comes down to what I need for my car  and then the demand.
While my two 240s are far from stock, every time I read a post showing NLA parts being reproduced makes me smile. Who knows I might have a third Z in my future, one I keep stock. Of course I would have to keep a third Z a secret from my wife.
A tip of the hat to nix240Z.
