I just cranked the volume here at work! NIIIIIICE! That is just with S.U.'s right? I don't think tripple sidedrafts are allowed in EP.
You are correct this is with the SU's. Here are some pics I took at VIR.
Got any details as to how the car is set up?
Member gira can speak to that much better than I can. Car finished 2nd in the Southeast division and is headed for the Runoffs in Oct.
The car is set up to SCCA EP rules.
The 240z is a limited prep car.
Cam is liimited to .500 lift
Compression to 12 to 1
Carbs twin Su's
15 x 7" wheels
Tranny factory 4 speed or weight penalty for the same factory box with internal gear changes. Another weight penality for use of a dog ring box.
It also is limted to 240Z calipers front with vented discs.
280ZX rear disc and calipers.
A few more things come to mind, but the car Greg has is fully developed under the rules.
Mike
