Give Danny's Datsuns a try. Just be sure to tell him to find you nice ones. I bought some water tubes from him and got some junk. He stands behind his parts and replaced them, but it was a hassle. But the replacement was very nice!
Danny's
541-430-1180
Good luck!
I bought a used one from Charlie Osborne (Zed Findings of Ontario, Canada) for my '73. I didn't notice 1) it was different from my original hinge and 2) the holes needed to be re-tapped but it worked anyway and wasn't too expensive. I went ahead and used because I had already re-painted it and my door jambs and wanted to hurry up and get my car back together to shoot th epaint on the body....
Bill,
You can rebuild them. Its a matter of replacing the pivot pins. Drill rod is a suitable material for pin replacement. Also, he recommends going to a slightly larger diameter than the stock pins, for obvious reasons. Drill rod is available in many diameteres.
I bought a brand new, still in the Nissan bags set for my 240 on ebay a while back. I am waiting til I get into the body to install them though. They are hard to find new, but call your Nissan dealer, they may have a way to get them. Check out courtesy nissan as well, I think I remember seeing some there.
