I was just curious what everybody currently adjusts their idle at. According to the Hayne's Manual, they had idles down at 550 and 700, where as my timing light recorded mine at about 1060. What is a correct idle, and what do all you have yours set at? Thanks all
https://www.classiczcars.com/forums/topic/13611-best-idle-speed/
I remember trying to set mine at about 550 like the decal under the hood suggested but it would stall. Especially when I would run the A/C. I think it idled best around 800. This was over a year ago so my memory is a little fuzzy.
At least on the 280Z, there is a vacuum thingy controlled by the vacuum solenoids to increase the idle speed when the a/c is on. Since I have no a/c, I took that off, along with the EGR which wasn't workling. I might put it back on to see if it would help, since it was sucking fresh air and not connected to the exhaust manifold. :(
I set mine at 7-8 degrees BTDT.
mention of a 280Z "vacuum thingy controlled by the vacuum solenoids to increase idle when a/c is on" has absolutely nothing to do with this thread about 240Z Timing and Idle RPM settings! :stupid:
