Skip to content
trivia
A rectal-cranial inversion is a head up your arse.
What is it to make your feces cohesive?
a high starch diet?
TomoHawk, I was thinking digits, not digit numbers-must have had a case of my question 3! I stold the 1812 question from Lenno-I could not believe the number of peopley I share a species and a planet with that said 1941!
Will
hey guys i get online to get out of math class LOL.
how many miles away from the sun is the earth.
Get your $hit together
Here's one.....
What year did Ford introduce the Pinto?
What structural defect caused Ford to quit making the Pinto?
Vicky
Vicky
1971?
Terminal Ugly! No, Ralph Naders' evaluation of the structural defect in the attatchment of the gas tank. A rear impact could and usually did cause the car to explode!
Will
Originally posted by hls30.com
Vicky
1971?
Will
Ding, Ding, Ding! You are correct on the gas tank explosion. I do believe the year is 1971. However, I heard on TV someone mentioned a 1969 Pinto. That's why I asked the question. I too thought the Pinto came out in '70 or '71.
hsl30.com your prize IS a Pinto even worse, a Pinto wagon, hehehe, tee hee. ROFL
Vicky
Can I get mine extra crispy?
I would rather have proof of an explosion, than be proof of an expolsion!
Will
AFAIK, the Pinto did come out in 71. I had one.:( Their recall and subsequent repair was to put a plasic shield behind the tank. In further tests, the shield also burned in the explosion.LOL
I don't believe that explosion junk they were always saying. To actually have an EXPLOSION , as in "BOOM!!" you gotta have just the right amount of vapor with a spark or something to ignite it.
The spark part is believeable, because in a collision, there's bound to be metal rubbing, which could cause a spark. The explosion part is the problem. Like I said, a gas tank, even FULL with 15 gallons, just won't explode. The worst that could happen is a really big flare up. That means you gotta have only FUMES in the tank.
The proof of the lack explosion comes from U.S. Coast Guard films I saw in the 70s where there were explosions of boats being refueled. They had to carefully control the vapor in the bottom of the boat (fuel vapor sinks) to get it to explode. Further science experiments in high school chem class (1980) confirmed the actual proportions and conditions.
So the next time you see a car on TV the flips over and everybody says "IT'S GONNA EXPLODE!!" You can laugh because you know it should just catch fire or flare up big at the most. Hollywood provides the BOOM! :D
BTW, Pintos had a V8 option with power steering??
