Note in the first pic that the voltage regulator and the fuel filter clip have both been moved rearward. The VR has been turned vertically and mounted partially on top of the manufacturer's plate. The outline of the VR's original mounting position can still be seen in the pic. They were probably moved to make room for the device.
ok if I was guessing I would have to go with air horns , actually can't make out what it was bit there was alot of it , it connected to my ignition a relay , not sure if I have more electrical issues but I doubt it and 4 toggle switches and two relays inside the engine compartment , from another post , not real big on electrical, this is my first z with anytype of electrical probs , here the pics of the carnage and after pics , thanks All :D Jeff
  • 3 weeks later...
yes nice new linkage thanks to z therapy , it helped alot to remove the smog stuff , not quite done still have a few hoses I am deciding what to do with but a great improvement
