Hi all -
I have a leaky right rear wheel cylinder and can't figure out how to get the rear drum off and the FSM basically says 'take it off.'
On most cars, there's a lock screw somewhere then you just smack the cover and yank it off but I can't find that screw and its driving me nuts lol
Anyone have an idea?
-chase
https://www.classiczcars.com/forums/topic/69665-rear-drum-cover-removal/
If the brake isn't locked up, and the wheel turns, the likely cause is rust between the axle flange and the brake drum. I'd use a few long penetrating oil soaks and use a hammer to hit the drum between the wheel studs a few times. My next choice would be heat.
Yep the wheels turn fine. Isn't there a lock screw that holds the drum on?
