Salvageable? - Interior - Classic Z Car Club Skip to content
Salvageable?
I'm pretty confident I can fill most the cracks... But one of the previous owners glued on a cover and there's a lot of rubber style glue everywhere
That rubber glue may be the least of your problems!
I've done a Z dash pad restoration, starting with something that had only 25% of the deterioration that yours has. Even at that, it was a time-consuming job. Not only does the pad surface need to be levelled (not easy to get right, given the multiple contours), it's also necessary to 'V' and then feather-edge all of the cracks so that the filler won't crack along the seams. I'll bet it would take you 20 man-hours of effort (or more) to level, edge-treat, fill, sand, and paint a dash pad like yours to a decent level of final finish.
But before you even get started down that road, you'll need to convince yourself that what's left of your original pad has enough structural integrity to prevent the pieces from moving around independently when the cabin temperature goes up or down. With its many full-depth cracks, I don't think I would trust your badly broken-up dash pad to meet that requirement. As a litmus test, it would be interesting to know whether a professional dash restorer like Just Dashes would accept your dash for restoration. Maybe you should send a picture and ask them.
IMO, your best path forward will be to either: 1) buy a used dash that offers a better starting point for a DIY restoration (as Siteunseen suggests), or; 2) buy one of the replacement dash pads that have recently become available. In the latter case, you unbolt the old pad from the underlying steel structure (known as the 'armature') and then bolt on the replacement pad. There are a couple of threads on this site that discuss these replacement pads. As a third, lowest-cost/effort alternative, you could just replace your old plastic dash cap with a new one.
Thanks for the input! The dash is a big project and i think im going to spend my time on the body of the car for now and set this aside. More than likely ill buy a new one vs repairing this one. there are so many issues with this one its beyond saving i think. might get a cracked one with only a few cracks vs 100.
Wow, that dash has got some issues! I guess the answer depends on your budget and focus. You could always find another one and go that route, or you can send it to a restoration shop like Just Dashes. However, with the screws and missing foam, you are probably better off finding a better dash to use as a base.
There are new dashes available for these cars. You should be able to find them with a search. I think they are around $1k
$840 (plus shipping) at Motorsport Auto.
