Rocker arm noise when accelerating in 3rd gear! Timing too advance?
  • 3 weeks later...
On 10/13/2025 at 5:01 AM, jonbill said:
It sounds like it. What head, compression ratio, fuel and ignition advance.
Hi Jon,
Mechanic just confirmed he had advanced the timing to get a quick response in first gear with the hot coil. Should i retard it a little bit? If so how much?
