Wiring bellows tubing - Body & Paint - Classic Z Car Club Skip to content
I'm putting power windows (one supplier option is JDMSPEED on Amazon) and may some day also add power door locks. Either way, I need to run wires into the doors. To do that, I want to make sure they are protected from getting crimped or severed during open/close operations. On my "modern" cars, each one has bespoke (don't you just love English?) rubber tubes protecting exactly these kinds of wires.
So, my question to those of you who have also run window, locks or speaker wires into your S30 doors is, what protection did you provide those wires?
I'm hoping the answers will be off-the-shelf items obtainable from a local dealership as I doubt the local AutoZone carries such things, but you please tell me. And, of course, any photos of your installations will be most appreciated.
Thanks, Patcon. I searched Amazon and eBay but apparently was not using the correct terminology to turn up what you have found.
Knowing the right search terms is the real trick. I did a first search and turned up the correct description and then searched with that. Some of those pieces look like plastic. Some look like rubber. I would prefer rubber if I could get it
Well, I'm going to buy one if only to determine if it could work in an S30. The bigger issue to me is where do I drill a 3/4" hole in the chassis? There are already smaller diameter holes on both sides for the dome light door switches and there's not much room in the same body recess (for the top door hinge) to drill below those. Placing the wiring boots above the door switches would run the risk of them being smashed by the top door hinge. If they're to be placed in the lower recess for the bottom door hinge I'm probably going to have to drill through two vertical panels. Details are always a PITA.
Seppi
I have done this project. I will post some pictures tomorrow. I followed a theard by Dave Irwin (zsonthebrain)?
My car is a "72" I removed the doors to drill the holes. If you can find his thread he shows where to drill. Dave provided me with the rubber boots.
Steve
SteveE: Thanks for your reply and I look forward to seeing your pix.
As it turns out, I have been collaborating with Dave Irwin (Zs-ondabrain) to update the thread to which you've referred so that it can be a permanent tech article with lots of pix for the S30 community. With luck I'll get that done later this fall.
First picture looking done from top
Second picture door side
Thrid picture body side
The boot was a straight section about 6" long. They came from Dave many years ago.
The boots have been installed for 5 or 6 years, but only used heavily for this past summer. All seems good!
I have power windows and power lock wires running through them.
Thanks for those pix, SteveE, as they are very helpful. Judging from its relationship with the door jamb light switch position, it looks to me like you drilled into the lower part of the upper door hinge recess on the body side.
I measured the bottom of that recess to be roughly 55 mm below the center of the lowest bolt securing the hinge to the body. In my photo below I've marked spot welds with small "dots" of black electrical tape and the bottom of the recess with the horizontal piece of tape. And the "X", you ask? That's where I'm going to center the 3/4" hole for the bootie, which pair should be arriving tomorrow.
As for the hole in the door, it looks like yours is at the same height at the lower door hinge bolt. From feeling around inside my door, that's where there's just a single thickness of metal (immediately below it feels like there's a double thickness). So my drill point there is also marked with an "X".20250921_172655[1].jpg
Damn, but that body metal is THICK at that location. I estimate it at 3 mm. Pretty near took all the life out of my Harbor Freight step drill bit.😊
Those spots look good. I used this beast and it was tough (was wondering why I didn't use a step drill 😄)
I did paint the bare metal in the holes.
Here is a picture of the motor installed
This is a Spal heavy duty unit (not sure if these are still available) Been working great. Important that the window works smoothly first !
