Saving- 04858 - Page 2 - Build Threads - Classic Z Car Club Skip to content
Saving- 04858
First project after getting the roof attached was the passenger front fender support . I had cut up two 240z’s years ago and had a whole front clip left.
No easy way to do this either .I was tempted to buy the sections from KF so I wouldn’t have to disassemble the front clip . In the end it worked out .
Edited by madkaw
More pics
On 9/21/2025 at 9:58 PM, madkaw said:
In the end I ended with a .250” gap which was acceptable to me .
How did you close that .25" gap?
Also: Please discuss your technique(s) for separating spot welds.
I couldn’t close the gap but I could fill it . The reason I made the sleeves was to give me adjustment . Ideally it would have been the perfect gap for a bead of weld . Since the sleeves are close to 3” long I was able to weld it strongly and then cosmetically fill the gaps . I had left over A pillar material which I used to fill that .250” gap .
Technics or tactics . They can be a MFers . I use the spot weld cutters you can buy cheaply anywhere . Predrill small hole for center pin and saw away . I did buy a pneumatic drill just for spot weld but it’s limited where it can be used . Finding the center of the spot weld helps to get all of the weld
  • 1 month later...
The passenger side was exceptionally bad in this car relative to other sections . The car sat outside on a rotisserie for years on its side with the passenger side down . Probably gathered water from rain . When I finally dug into this I was grateful I had scrap pieces to do some of these repairs . Somehow I was missing a hunk that I had to make - but it’s was a small hunk . Removing the firewall and all its spot welds really tears up the kick panel . That and rust required some patching work to make the kick panel strong again . I probably will end up ordering the panel for under the battery tray from KF Vintage . I don’t think my skills are up to fabbing that panel .
Thanks for this latest photo essay. Lots of good insights here into how multiple panels come together in this complicated and structurally-important section of the car.
You did some very nice work in forming the two big replacement sections for the upper frame rail. Can you talk a bit about how this was done? Also: What was the gauge of the sheet metal you used?
In the 4th photo, there's what appears to be a right-angle drive power tool, with a 3" sanding disk mounted in the chuck. Is this your go-to tool for grinding welds? Who makes it?
I didn’t make the larger pieces of upper frame rail. Same car I bought my roof from I also bought all his straight scrap pieces . It was enough of a challenge to make that 1” filler strip between the pieces he sent me - ha . I don’t have the tools to do that complex of bends and curves.
The tool is just a right angle air grinder with a Roloc sanding discs . I use that tool more than most . I have cut- off wheel mandrel and scotch bright disc options . I actually have 3 of them with different mandrels on each .
Edited by madkaw
The next thing to attack is the firewalls . I can’t finish the passenger upper frame because I need access to spot weld the firewall panel . The firewall is sandwiched between the inner fender wall and outer . I also have an issue with the passenger side firewall panel from KF . The drivers side worked out pretty sweet and I should be able to do a decent job welding it in . The biggest obstacle is that I wanted to preserve the vin# that’s stamped on the wall so I had to cut around it . The passenger side doesn’t line up right as you can see but the pics . They said they will send me a new one . I think the panel wasn’t square on their stamping machine . KF has been really good supporting their products .
I’ll also add that their drivers firewall panel does not include the doubler for the inside
I thought it would be prudent to assemble what I have so when I do the other side floors and such I have my gaps set on the drivers side already . The tunnel is pretty flimsy at this point . The passenger side just scares me as far apart as I have it .
