First project after getting the roof attached was the passenger front fender support . I had cut up two 240z’s years ago and had a whole front clip left.
No easy way to do this either .I was tempted to buy the sections from KF so I wouldn’t have to disassemble the front clip . In the end it worked out .
Edited by madkaw
7 hours ago, Namerow said:
How did you close that .25" gap?
I couldn’t close the gap but I could fill it . The reason I made the sleeves was to give me adjustment . Ideally it would have been the perfect gap for a bead of weld . Since the sleeves are close to 3” long I was able to weld it strongly and then cosmetically fill the gaps . I had left over A pillar material which I used to fill that .250” gap .
6 hours ago, Namerow said:
Also: Please discuss your technique(s) for separating spot welds.
Technics or tactics . They can be a MFers . I use the spot weld cutters you can buy cheaply anywhere . Predrill small hole for center pin and saw away . I did buy a pneumatic drill just for spot weld but it’s limited where it can be used . Finding the center of the spot weld helps to get all of the weld
