Hi guys,
I am chasing some oil leaks, and I finally removed the transmission to find out that the rear main seal is leaking (I replaced the side seals a few weeks ago):
I wanted to ask you if I should replace the clutch that I had the shop install 15 years ago. The car has put 1000 miles since then.
The clutch plate doesn't look worn out as far as thickness goes. There are some grooves in it, but running a finger nail against then doesn't feel deep. The engine flywheel is smooth, no scratches. The clutch didn't slip. I replaced the master/slave clutch cylinders a month ago.
Here are some pictures of the clutch plate:
I also don't see any leaks around the front transmission seal/gasket area. It looks like the shop replaced it (I see the 'new' paper gasket sticking out):
The throw-out bearing is smooth, no noise while spinning.
Should I replace the clutch and re-do the front seal/gasket of the transmission? I got the replacement parts from the ZCarDepot just in case.
Thanks!
The Rear main seal is still available from Nissan the last time I checked. The rest looks good. Be carefull tapping in the new seal from Nissan. I don’t advise shortcuts from other vendors as far as the rear main.
Edited by Yarb
I wouldn't have any problem reusing that clutch. I'd replace the seal and reuse everything else.
Don't forget a little bit of new EP grease on the pilot bushing.
Great, thanks guys - I feel better now since I know that the auto shop actually replaced the front gasket. I bought a rear main seal from Rockauto, Mahle, JV637, made in Japan. Looks very solid.
The last question - the inside lip of the rear main seal per Tom's book will be coated with moly/petroleum jelly.
What about the outside seal surface and inside the engine where the seal goes? Wipe it clean with a solvent? Should I smear some aviation permatex on the outside of the seal before its installation?
Thank you.
Sometimes new seals come with some little dabs of lube already on the inside lip. If yours did not, you can just use motor oil, or my favorite... silicone grease.
As for the outside surface, I would do the same there. Motor oil or silicone grease. I wouldn't use anything that sticks like the aviation permatex. In my experience, the outside of the seal has significant interference with the hole you press it into. In fact, I've had to hit them harder than I was comfortable with just to get them seated into place. If your experience is like mine, you'll be thankful for the slippy on the OD, not the sticky.
Use your old seal as a protection ring to tap your new one into place. And make sure the new one is square when you are done.
I tried using the sharp punch tool/screw extraction method while removing the seal. It immediately moved sideways inside. I was able to use a hook tool to extract the seal out.
If anyone is interested, I found a plumbing part at Menard's that can be used for the installation. It is called '4x3 Red Bushing Con, SXH SDR35 SW' in the Plumbing section. Its inside diameter fits nicely over the crank. Once the seal is positioned, it was easy to tap it in. I had to dremel inside a little to make sure the 'tool' sits flush:
Thanks to everyone for your input.
I lost my clutch alignment tool from the Exedy kit, had to order a new one at O'Reilly's.
Update: put the transmission back with the Dorman $6 clutch alignment tool for 24 splines.
Installed 2 guide bolts (don't forget to put slots into them, otherwise you won't be able to remove them). The transmission was in 1st gear, I moved the rear shaft a little to help it ease into the clutch splines. It took 10 minutes.
Here is my improvised flywheel hold tool (saw some guys on youtube doing this):
Next is the driveshaft, refill the tranny and exhaust mounting.
