1978 280z
I want to replace my fusible link holder with a new blade fuse box. When I search here, I get thousands of post to review. Many fuse boxes are listed on Amazon and other sites. Any thoughts on the better ones to use?
Edited by mayolives
spell
On 5/22/2025 at 8:32 AM, mayolives said:
1978 280z
Find a weather resistant maxi fuse (or ANL fuse) holder if you are planning to mount the fuse holder where the current fusible link holders reside. I also suggest using ferrules on the wire ends to improve clamping force on the wires. You will need to find a ferrule crimper that can handle the wire sizes (relatively easy to find on Amazon).
Here is an example of a marine ANL fuse holder: https://www.crutchfield.com/p_867FUSEDIS/Wet-Sounds-WWX-FUSE.html
