July 27, 20214 yr Author comment_625783 You CAN use a broken handle on the other side but I did not realize it will not fully hold the handle in the door. When pulled it will half come out and fells like after a few pulls and open and close of the door a few times it will break right off. Better to just get a new one. Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/?&page=2#findComment-625783 Share on other sites More sharing options...
July 27, 20214 yr comment_625794 4 hours ago, Shawninvancouver said: You CAN use a broken handle on the other side but I did not realize it will not fully hold the handle in the door. When pulled it will half come out and fells like after a few pulls and open and close of the door a few times it will break right off. Better to just get a new one. Yours must have broken at a different spot than normal. They generally break on the arm where it meets the base. I've swapped them many times and the offside arm serves no purpose, so with it broken off, once the handles are swapped, they function perfectly. Yours must have broken lower on the casting where it actually mounts to the door. I've never seen one break there. Weird. Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/?&page=2#findComment-625794 Share on other sites More sharing options...
July 27, 20214 yr Author comment_625806 I have 2 that both broke in the exact same spot. Just above where rod clicks into handle. When it brakes there once screwed to car the handle pulls out of the door. Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/?&page=2#findComment-625806 Share on other sites More sharing options...
July 28, 20214 yr comment_625834 22 hours ago, Jeff G 78 said: Yours must have broken at a different spot than normal. They generally break on the arm where it meets the base. I've swapped them many times and the offside arm serves no purpose, so with it broken off, once the handles are swapped, they function perfectly. Yours must have broken lower on the casting where it actually mounts to the door. I've never seen one break there. Weird. This has been my experience also. Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/?&page=2#findComment-625834 Share on other sites More sharing options...
July 28, 20214 yr Author comment_625845 I have a few that hAve broken I. Different spots. I think I found one just broken on top where rod goes. That one should work. Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/?&page=2#findComment-625845 Share on other sites More sharing options...
July 28, 20214 yr comment_625854 As I look back over this thread we should have asked you for a picture of the broken handle so we could have helped you better. Link to comment https://www.classiczcars.com/forums/topic/65618-can-i-use-broken-drivers-side-door-handle-on-passenger-side/?&page=2#findComment-625854 Share on other sites More sharing options...
