i just watched a video i did of checking for power at the coil area..  power goes to one side of the balast but does not come out the other side  and does not get power to the coil..  is that correct???
ok...   that is something to check .. i never knew there was a wire under there  - thought it was a solid block... i have this one.. will it work??
only two prongs on this one..  came with coil,,,,  my balast resistor did get pretty toast when trying to start car..
