Tuning With An Air/Fuel Gauge - Page 20 - Fuel Injection - Classic Z Car Club Skip to content
Trying to jump 9 & 12 to trigger high-altitude mode (I'm at 6,000') and I must have the ECU pin harness misread. I am not finding pin numbers on the harness case, and relied on counting, ref the FSM. If I am correct, there is not a slot for 10 or 11 on my harness. If I am wrong, I jumped 24 and 27, which may explain why on reassembly it ran terrible poor, then died.
Any clarifying wisdom is greatly appreciated!
I'm not sure that high altitude mode was even ever included on all models. Are you sure that your ECU supports the altitude switch?
Are you sticking that jumper wire in there and then trying to attach the connector to the ECU? It seems to me like that little jumper wire is going to get in the way and you will not be able to get the connector to seat correctly?
All that said... Here's a pic looking into the harness on the car:
And here's a pic looking into the ECU connector:
Oh, and by the way... You jumpered pins 7 and 10. Shorted the AFM slider to +12 battery. That can't do good things to how it runs.
that is an awful idea - why are you doing that?
Go here, click "Start new topic" and start your own thread - https://www.classiczcars.com/forums/forum/27-fuel-injection/
Then go here and download the 1980 EFI book. It has all years from 1975 through 1980. Go to EFI Troubleshooting - https://www.classiczcars.com/files/file/32-efi-book-1980/
As CO suggested, you'd really have to force that connector on to the ECU to get that wire squashed in to place. It's also in the way of pins 8 and 9. Not clear how you accomplished that.
And, re CO, the compensator was only present on California models.
on my 78, when I was messing with this before the entire thread started, I did the same thing you did, but in the harness connector the altitude sensor plugs into rather than trying to fit a piece of wire in the ecu connector. the altitude sensor sits in the drivers footwell near the steering column.
Edited by chaseincats
