Posted March 4, 20196 yr comment_570007 Just got the complete set lf msa 3 point seat belts for my 1972 240z. Will i be able to use the stock receivers or just the one from the kit. I read that i also have to remove the center console to fasten the buckle holder in case i wont be able to use the stock ones. Anyone? Link to comment https://www.classiczcars.com/forums/topic/61720-how-to-install-3-point-retractable-msa-seatbelts/ Share on other sites More sharing options...
March 4, 20196 yr comment_570058 I used a different set from Wesco because it can be installed in the series 1 car without having to drill additional holes. I didn't have to remove the console for the inner buckle strap install. I used the stock attachment point that is accessible without removing the console. I doubt the MSA belt would require console removal, from the picture it looks like the inner belt piece uses the stock mounting point too. https://www.wescoperformance.com/roadster-seat-belt-eb.html Link to comment https://www.classiczcars.com/forums/topic/61720-how-to-install-3-point-retractable-msa-seatbelts/#findComment-570058 Share on other sites More sharing options...
March 10, 20196 yr Author comment_570610 You still have not told me how did you installed the retro belt msa seatbelt sets. The kit even brought this holder but no instructions on how and where it is installed. Link to comment https://www.classiczcars.com/forums/topic/61720-how-to-install-3-point-retractable-msa-seatbelts/#findComment-570610 Share on other sites More sharing options...
May 10, 20196 yr comment_575161 I'm probably late to the party but that extra piece goes under the center console to hold the two receivers from falling in-between the seats. That's also why it says you have to remove the center console. Link to comment https://www.classiczcars.com/forums/topic/61720-how-to-install-3-point-retractable-msa-seatbelts/#findComment-575161 Share on other sites More sharing options...
May 10, 20196 yr comment_575186 Adding @Joseph@TheZStore and @James@TheZStore, they may have some tips... Mike Link to comment https://www.classiczcars.com/forums/topic/61720-how-to-install-3-point-retractable-msa-seatbelts/#findComment-575186 Share on other sites More sharing options...
May 10, 20196 yr Author comment_575189 How exactly do you fasten this seatbelt holder? Link to comment https://www.classiczcars.com/forums/topic/61720-how-to-install-3-point-retractable-msa-seatbelts/#findComment-575189 Share on other sites More sharing options...
May 10, 20196 yr Vendor comment_575196 The seat belt holder is mounted underneath the center console using the forward mounting screw inside the recessed area. Link to comment https://www.classiczcars.com/forums/topic/61720-how-to-install-3-point-retractable-msa-seatbelts/#findComment-575196 Share on other sites More sharing options...
May 13, 20195 yr Author comment_575363 Thankd Link to comment https://www.classiczcars.com/forums/topic/61720-how-to-install-3-point-retractable-msa-seatbelts/#findComment-575363 Share on other sites More sharing options...
