Posted
Ztherapy refurbished both of my 3 sscrews roundtop SU Carbs and install Brand new SM Needles on them. My car engine is not stock it has been upgraded to 2.6 L with oversized pistons and a Shneider 274F Camshaft. Should i consider changing the needles to another type to get a better performance at idle?
Idle is Idle is Idle.  The only thing to worry about is too rich a mixture that stinks and fouls plugs.  Anything from 13 to 16 usually works. 14 to 15 is the least stinky.  13 is  more tractable and sounds better.
Nice! But quite expensive! im using the gunson colortune. Ill let the car warm up and race the car for 10 to 15 mins and then pull the plugs out to see if i can achieve the dark Brown color on the plugs.
Edited by jalexquijano
I had a colortune and it was nice at idle but couldn't see what was happening while driving on the street. Also with modern unleaded gas it's difficult to base everything on the color of the plugs.
anyone else bought this a/f sensor?  i want to see which is the correct spark plug color i must achieve
