April 22, 20178 yr comment_518791 Yes, im using it. What would you like to know? Link to comment https://www.classiczcars.com/forums/topic/56978-too-good-to-be-true-%E2%80%93-125-amp-bolt-in-alternator-datsun-store/?&page=5#findComment-518791 Share on other sites More sharing options...
May 19, 20178 yr comment_521327 Yes, im using it. What would you like to know?Just looking for some insight. I am running the common zx 60amp alternator upgrade which we all know is not known for producing low idle amps. I have added accessories such as electric fan, electronic ignition,etc and at idle my volts drop down to around 12volts and my charge light comes on suggesting low charge from alternator. Causing problems as a result. Car will almost stall. When revving motor or driving therfore at higher rpm the light goes out and volt meter shows the needed 14 volts? My optima battery is new and in good working condition. Connections are clean of any oxidation etc. New larger gauge battery cables,etc.My thinking was I need an alternator that produces more low rpm/idle volts. So this alternator sounds like it does just that. Not sure what set up your running but does this alternator provide the low rpm amps as claimed,etc. Any insight or advice appreciated.Sent from my SM-T377V using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/56978-too-good-to-be-true-%E2%80%93-125-amp-bolt-in-alternator-datsun-store/?&page=5#findComment-521327 Share on other sites More sharing options...
May 21, 20178 yr comment_521452 It does already load at 700 rpms. mine idles at 700 and with all accessories on (Stereo, Heating blower full speed, Electronic ign and pump) switch the lights on and of gives a little hickup but thats all. What you loose with this alternator is the charge light. Link to comment https://www.classiczcars.com/forums/topic/56978-too-good-to-be-true-%E2%80%93-125-amp-bolt-in-alternator-datsun-store/?&page=5#findComment-521452 Share on other sites More sharing options...
September 21, 20186 yr comment_557887 FYI I just emailed zspecialties and he is still making these. I'm going to pick it up next week since I am local to him. What I would like to know is what does the charge light actually do? Does it indicate overcharging or something? Link to comment https://www.classiczcars.com/forums/topic/56978-too-good-to-be-true-%E2%80%93-125-amp-bolt-in-alternator-datsun-store/?&page=5#findComment-557887 Share on other sites More sharing options...
September 21, 20186 yr comment_557890 2 hours ago, AlbatrossCafe said: Does it indicate overcharging or something? Pending failure. You could probably get it to work. Zspecialites could have designed his to work. Link to comment https://www.classiczcars.com/forums/topic/56978-too-good-to-be-true-%E2%80%93-125-amp-bolt-in-alternator-datsun-store/?&page=5#findComment-557890 Share on other sites More sharing options...
