Skip to content
Weber selection and initial jet tuning
F15 is another but it is supposed to be better suited for smaller cylinders.... leaner.  I'm not sure where it is lean.  Going to be a big experiment for the better good of L28 owners.
On 8/21/2017 at 7:29 AM, Patcon said:
When I start tuning some triples I might be able to help lighten your load...
+1 when you are done let us know what extras you have
Haven't gotten a new log yet because my 2 year old decided to hide my SD card somewhere.  So, had to order a new one. Should have it in a day or two.
Got a new SD card and finally dry weather. Took a log this morning and I'll take another on the way home. Just watching it though, it looks to be pretty lean. So...might be headed back to the 155/225 combo for a baseline before E Tube experimentation.
Very strange.  I wonder if we are battling manufacturing variance?
Weber used to flow test every jet before stamping with values based on flow measured (not drill bit size). I doubt modern suppliers of jets do this or even change or measure their drill bits often enough.
Edited by 240260280
36982419611_c8328d1e32_o.jpg9-8-17 by blodi, on Flickr
Go back to 155/225? Or maybe leave the 160 in and go 160/225?
Very strange.  The middle hump raised.  No flattening occurred,   Try the 165 to add more fuel.
Maybe a free-air recalibration is needed too.
Edited by 240260280
