January 12, 20178 yr comment_510092 I can't remember right off, I'll look in my file and see if I can find the receipt. Â It's for a ZX, I know that. Â Seems like I had a hard time finding a timing kit for a 2.4 then someone said the racers use ZX kits so that's what I bought. Â Power Line I think. After fiddling with carbs floats for a couple of weeks I finally got them at 23mm. Â Tuned the nozzles and ended up at 3 1/2 turns down. Â My car finally runs like the other 240 I had, it pulls hard until the redline then I shift up. Â So damn happy! Â Edited January 12, 20178 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-510092 Share on other sites More sharing options...
January 12, 20178 yr comment_510094 Loading my clothes and looked up to see this. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-510094 Share on other sites More sharing options...
January 13, 20178 yr Author comment_510159 21 hours ago, siteunseen said: I can't remember right off, I'll look in my file and see if I can find the receipt.  It's for a ZX, I know that.  Seems like I had a hard time finding a timing kit for a 2.4 then someone said the racers use ZX kits so that's what I bought.  Power Line I think. After fiddling with carbs floats for a couple of weeks I finally got them at 23mm.  Tuned the nozzles and ended up at 3 1/2 turns down.  My car finally runs like the other 240 I had, it pulls hard until the redline then I shift up.  So damn happy!  thats fantastic!! I just received my float-sync tool going to try it this weekend and see how it goes. I'm also going to remove my choke cables when I do the carb adjustments, I want to make sure the chokes don't interfere with the balancing.   20 hours ago, siteunseen said: Loading my clothes and looked up to see this. Thanks! Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-510159 Share on other sites More sharing options...
January 14, 20178 yr Author comment_510249 Front and rear float levels, almost 23mm. Also a video of it idling, pretty smooth. Unsure if it's charging so I had the battery maintainer on it. That's another issue to check. IMG_4515.MOV Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-510249 Share on other sites More sharing options...
May 25, 20178 yr Author comment_521701 I apologize for not updating sooner, but I really don't have the time to work on the car only between semesters. So now that the timing issue is sort of fixed I moved on to the carbs. I bought a Gunson colortune, very simple in it's operation. I'm not sure if anyone here has used it but you adjust the carbs until the flame in at the color tune is blue. I was able to adjust the rear carb to get a blue flame but the front is rich. The car is so rich that it wouldn't start back up at the gas station. I can't seem to figure this out. I am going to check the aftermarket mechanical fuel pump pressure to see if it is less than 3.5psi. I don't know what else to do at this point. My floats are good, I adjusted the a/f adjustment by 1 turn roughly, all my emission equipment is disconnected and capped.    Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-521701 Share on other sites More sharing options...
May 25, 20178 yr comment_521722  Are the fuel nozzles both in the up (un-choked) position? Occasionally, that metal linkage bit from the cable to the nozzle can get a bit of a twist in it and prevent the nozzle from sliding up when the choke is off. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-521722 Share on other sites More sharing options...
May 25, 20178 yr comment_521734 That happened to one of mine before. Â The nozzle was stuck. Â I had unhook everything and drop the nozzle then sand the brass down smooth. Â It was coated with a varnishy coating from sitting too long. Good eye Mark, hopefully. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-521734 Share on other sites More sharing options...
May 25, 20178 yr comment_521736  When I had one stick, the cure was twisting that little flat bar linkage bit to align it better to the nozzle, The surface that the screw passes thru wasn't parallel with the mounting surface on the nozzle causing it to bind. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-521736 Share on other sites More sharing options...
May 25, 20178 yr Author comment_521737 Should I disconnect the choke cable completely?Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-521737 Share on other sites More sharing options...
May 25, 20178 yr comment_521738 Unhook the cable and see if you can move it up and down. Â I'd think if it movs any it's in that flat metal bar Mark's talking about. Â It should move up and down about an inch with the choke cable undone, freely by hand. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-521738 Share on other sites More sharing options...
May 25, 20178 yr comment_521739 Oh and mark the cable location on it's hold down clamp with a Sharpie or something so you'll be sure and get it back right. Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-521739 Share on other sites More sharing options...
May 26, 20178 yr Author comment_521744 I always manually put both chokes on at the carbs when I start the car and then pull the cable inside the car to keep the chokes on. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/52647-engine-only-runs-with-starter-fluid/?&page=15#findComment-521744 Share on other sites More sharing options...
